Local Time 23:55 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb V5.07.07a20: Now with added MQTT
Posted: 07:46pm 21 Feb 2023
V5.07.07a20
PicoMiteWebV5.07.07a20.zip
New commands
WEB MQTT CONNECT ip_address$, port, username$, password$ [, interrupt]
WEB MQTT PUBLISH topic$, message$, [,qos] [,retain]
qos defaults to 1 - valid 0, 1, or 2
retain defaults to 0 - valid 0 or 1
WEB MQTT SUBSCRIBE topic$ [,qos]
qos defaults to 0 - valid 0, 1, or 2 - don't ask me what it does
WEB MQTT UNSUBSCRIBE topic$
WEB MQTT CLOSE
MM.TOPIC$ 'contains the last topic received
MM.MESSAGE$ 'contains the last message received
example program
WEB ntp
WEB mqtt close
WEB mqtt connect "192.168.1.108", 1883, "mqtt", "*****", myint
WEB mqtt subscribe "thermo"
Bitbang humid gp1,a,b,1
WEB mqtt publish "thermo","The temperature at "+Time$+" is "+Str$(a)
Pause 2000
Loop
Sub myint
Print mm.topic$,":",mm.message$
End Sub
I've tested it on a MOSQUITTO broker running on my PC (easy to get up and running)
At the moment does not support TLS port 8883
Edited 2023-02-22 05:56 by matherp
Pluto
Posted: 08:16pm 21 Feb 2023
Just started to learn about MQTT. QOS=Quality Of Service.
  Quote  MQTT can send messages with different so-called "Quality of Service" levels.
This means the publisher and subscriber can choose how reliably a message will be sent.
Pluto
Posted: 08:19pm 21 Feb 2023
QoS level 0
Quality of Service (QoS) level 0 means messages are sent without any confirmation from the receiver. This means it is possible for a message to get lost, given an unreliable connection.
QoS level 1
QoS level 1 means the receiver must send a confirmation to let the sender know that the message was received.
However, with QoS 1, the receiver may get a single message multiple times. This QoS level ensures that a message makes it from sender to receiver but fails to ensure that it is received exactly once.
QoS level 2
QoS level 2 uses a four-step communication process to ensure a message is sent exactly once only, which can be necessary depending on the use case.
Source: https://elearning.easygenerator.com/
grroel.tech
Posted: 01:07pm 22 Feb 2023
Hello,
Good job, the MQTT works fine:
It is a pity that PicoMite does not have support for the BME280 sensor.
Best regards.
Posted: 01:22pm 22 Feb 2023
There is Basic code for the BME280 on this site somewhere.
My question about QOS is what setting it in Subscribe does. I. Understand its use in publish.
Pluto
Posted: 01:54pm 22 Feb 2023
BME280
RonnS
Posted: 05:52pm 22 Feb 2023
and it works fine
  Pluto said  BME280
Pluto
Posted: 07:12pm 22 Feb 2023
I am also using it since a few years back. Thanks to Peter!
LucV
Posted: 07:45pm 22 Feb 2023
Great job Peter !! Fantastic !!!
Runs without a problem.
I am using my own Raspberry Pi Zero W as a broker.
Publish and subscribe without a problem.
I only saw that the username and password are required even if the broker does not use them. So I filled 11 in as username and 11 as password.
Thank you
Luc's tech Blog
Pluto
Posted: 09:00pm 22 Feb 2023
  matherp said  My question about QOS is what setting it in Subscribe does. I. Understand its use in publish.
If I understand correctly, a subscriber can also demand the level of "QoS" (Quality of Service). If the subscriber demands QoS=1, the subscriber demands that the message will be repeatedly sent until the subscriber sends an Acknowledge (PUBACK,publish acknowledgment) back to the "broker". For QoS=0 no Acknowledgement is required by the subscriber. Not sure if the MQTT-broker can overrun the QoS wishes of the subscriber.
homa
Posted: 06:16pm 29 Jul 2023
  LucV said  Great job Peter !! Fantastic !!!
Thank you
Hi Luc,
Can you have a look here? Thanks.
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16080
Matthias
richard59715
Posted: 02:13am 22 Jul 2026
I have webmite 6.03 on pico W connected to my local network on IP 192.168.1.157 and an mqtt broker on 192.168.1.107. I can run mosquitto_sub -h 192.168.1.107 -p 1883 -u test -P c16txtxx -t pump/p -v on any machine on the network and it connects indicating the broker is configured correctly. But this code:
WEB MQTT close
WEB MQTT CONNECT "192.168.1.107", 1883, "test", "c16txtxx"
DO
   BME280_Read temp, hum, press
   PRINT "Temperature: ", temp, " F"
   PRINT "Humidity:    ", hum, " %"
   PRINT "Pressure:    ", press, " inHg"
   PRINT
WEB MQTT PUBLISH "Test T", str$(temp)), 1, 0
   PAUSE 5000
LOOP
fails on line WEB MQTT CONNECT
with:Connecting to 192.168.1.107 port 1883
[145] WEB MQTT CONNECT "192.168.1.107", 1883, "test", "c16txtxx",mqttint
Error : Failed to connect
What am I doing wrong?
Posted: 07:51am 22 Jul 2026
It is probably a firewall/permissioning issue on the PC, I haven't tested recently but remember it was a nightmare getting it set up when I first implemented the code. The 6.03.00 mqtt code was tested against remote brokers without any issues so I'm reasonably confident in it. Try the following program. Assuming it works (does for me)  change it to point to your local broker
Edit the two Const lines at the top and add credentials to the Connect line if needed:
Const Broker$ = "192.168.1.x"    ' their local broker
Const Port    = 1883
Web Mqtt Connect Broker$, Port, "user", "pass", OnMqtt   ' if the broker needs auth
' mqtt_test.bas  -  MQTT round-trip test against a public external broker
' Purpose: prove the WebMite MQTT client works end-to-end (CONNECT, SUBSCRIBE,
' PUBLISH, incoming message, UNSUBSCRIBE, CLOSE) against an anonymous broker
' on plain port 1883 (no TLS). If this passes but your LOCAL broker fails,
' the problem is with the local broker's configuration / permissions
' (anonymous access, ACLs, listener binding, firewall) - not the MMBasic code.
' The broker below is public and allows anonymous connections on port 1883.
' Swap Broker$ for "test.mosquitto.org" if hivemq is unreachable.
Const Broker$ = "broker.hivemq.com"      ' public, anonymous, plain MQTT
Const Port    = 1883                     ' plain (non-TLS) MQTT port
Dim mqttGot = 0                          ' set by the OnMqtt interrupt
Sub OnMqtt
 mqttGot = 1
End Sub
' Unique topic + payload so a stale retained message can't fool us
Dim Integer stamp = Timer Mod 1000000
Dim topic$ = "picomite-test/" + Str$(stamp)
Dim msg$   = "hello-" + Str$(stamp)
Dim Integer t
Print
Print "MQTT external-broker test"
Print "-------------------------"
Print "Local IP   : "; MM.Info$(IP Address)
Print "Broker     : "; Broker$; " : "; Str$(Port)
Print "Topic      : "; topic$
Print "Payload    : "; msg$
Print
' --- CONNECT (anonymous: empty user + empty password) ----------------------
mqttGot = 0
On Error Skip 1
Web Mqtt Connect Broker$, Port, "", "", OnMqtt
If MM.ErrNo <> 0 Then
 Print "CONNECT   : FAIL - "; MM.ErrMsg$
 Print
 Print "Could not reach the external broker. Check WiFi / DNS / internet."
 End
EndIf
Print "CONNECT   : OK"
' --- SUBSCRIBE -------------------------------------------------------------
On Error Skip 1
Web Mqtt Subscribe topic$
 Print "SUBSCRIBE : FAIL - "; MM.ErrMsg$
 Web Mqtt Close
 End
EndIf
Print "SUBSCRIBE : OK"
' Let the SUBACK land before we publish
Pause 200
' --- PUBLISH ---------------------------------------------------------------
On Error Skip 1
Web Mqtt Publish topic$, msg$
 Print "PUBLISH   : FAIL - "; MM.ErrMsg$
 Web Mqtt Close
 End
EndIf
Print "PUBLISH   : OK"
' --- WAIT FOR ROUND-TRIP ---------------------------------------------------
t = Timer + 5000
Do While Timer < t And mqttGot = 0
 Pause 50
Loop
Print
If mqttGot Then
 Print "ROUND-TRIP: OK - message came back"
 Print "  topic   : "; MM.Topic$;   " ("; Choice(MM.Topic$   = topic$, "match", "MISMATCH"); ")"
 Print "  payload : "; MM.Message$; " ("; Choice(MM.Message$ = msg$,   "match", "MISMATCH"); ")"
 Print
 Print "PASS - external MQTT works. If your LOCAL broker fails, it is a"
 Print "       broker permission/config issue, not the firmware."
Else
 Print "ROUND-TRIP: FAIL - no message received within 5 s"
 Print "  Broker accepted CONNECT/SUBSCRIBE/PUBLISH but did not echo back."
EndIf
On Error Skip 1
Web Mqtt Unsubscribe topic$
Web Mqtt Close
Print
Print "Done."
End
richard59715
Posted: 02:33am 24 Jul 2026
Thanks for help. Turns out my ubuntu server with mosquitto broker had port 1883 blocked for external connections. Thanks for help.
Also I ran program on pico w and did not have the I2C BME 280 connected and the program panicked after a while.
I put on pico 2W with BME280 connected and it seems to be running fine.
Does I2C crash the system if the I2C device is not present?
Also I did not see the post on a program for reading the BME280 so I had AI do it and it did a fair job with the basic program, just had the I2C commands wrong but all that complex logic to read the temperature, humidity and pressure and calibrate was done correctly!
Here it is for anyone interested:
'   BME280 Driver for WebMite/MMBasic
'   I2C Address = 0x76
CONST BME_ADDR = &H77
SETPIN GP4, GP5, I2C
DIM INTEGER T1, T2, T3
DIM INTEGER P1, P2, P3, P4, P5, P6, P7, P8, P9
DIM INTEGER H1, H2, H3, H4, H5, H6
DIM INTEGER t_fine
' Unified 16bit conversion (replaces CVT)
FUNCTION WORD16(lo, hi, signed)
   LOCAL v
   v = lo + hi * 256
   IF signed THEN
       IF v > 32767 THEN v = v - 65536
   ENDIF
   WORD16 = v
END FUNCTION
' Initialize BME280
SUB BME280_Init
   I2C OPEN 100, 100   ' new WebMite syntax
   ' Humidity oversampling
   I2C WRITE BME_ADDR, 0, 2, &HF2, &H01
   ' Temp/Pressure oversampling + Normal mode
   I2C WRITE BME_ADDR, 0, 2, &HF4, &H27
   ' Standby + Filter
   I2C WRITE BME_ADDR, 0, 2, &HF5, &H00
   BME280_ReadCalibration
END SUB
' Read calibration registers
SUB BME280_ReadCalibration
   LOCAL calib1$, calib2$
   I2C WRITE BME_ADDR, 0, 1, &H88
   I2C READ  BME_ADDR, 0, 26, calib1$
   I2C WRITE BME_ADDR, 0, 1, &HE1
   I2C READ  BME_ADDR, 0, 7, calib2$
   ' Temperature
   T1 = WORD16(ASC(MID$(calib1$,1,1)), ASC(MID$(calib1$,2,1)), 0)
   T2 = WORD16(ASC(MID$(calib1$,3,1)), ASC(MID$(calib1$,4,1)), 1)
   T3 = WORD16(ASC(MID$(calib1$,5,1)), ASC(MID$(calib1$,6,1)), 1)
   ' Pressure
   P1 = WORD16(ASC(MID$(calib1$,7,1)), ASC(MID$(calib1$,8,1)), 0)
   P2 = WORD16(ASC(MID$(calib1$,9,1)), ASC(MID$(calib1$,10,1)), 1)
   P3 = WORD16(ASC(MID$(calib1$,11,1)), ASC(MID$(calib1$,12,1)), 1)
   P4 = WORD16(ASC(MID$(calib1$,13,1)), ASC(MID$(calib1$,14,1)), 1)
   P5 = WORD16(ASC(MID$(calib1$,15,1)), ASC(MID$(calib1$,16,1)), 1)
   P6 = WORD16(ASC(MID$(calib1$,17,1)), ASC(MID$(calib1$,18,1)), 1)
   P7 = WORD16(ASC(MID$(calib1$,19,1)), ASC(MID$(calib1$,20,1)), 1)
   P8 = WORD16(ASC(MID$(calib1$,21,1)), ASC(MID$(calib1$,22,1)), 1)
   P9 = WORD16(ASC(MID$(calib1$,23,1)), ASC(MID$(calib1$,24,1)), 1)
   ' Humidity
   H1 = ASC(MID$(calib1$,26,1))
   H2 = WORD16(ASC(MID$(calib2$,1,1)), ASC(MID$(calib2$,2,1)), 1)
   H3 = ASC(MID$(calib2$,3,1))
   H4 = (ASC(MID$(calib2$,4,1)) << 4) OR (ASC(MID$(calib2$,5,1)) AND &H0F)
   H5 = (ASC(MID$(calib2$,6,1)) << 4) OR (ASC(MID$(calib2$,5,1)) >> 4)
   H6 = ASC(MID$(calib2$,7,1))
   IF H6 > 127 THEN H6 = H6 - 256
END SUB
' Read raw sensor data
SUB BME280_ReadRaw temp_raw, press_raw, hum_raw
   LOCAL raw$
   I2C WRITE BME_ADDR, 0, 1, &HF7
   I2C READ  BME_ADDR, 0, 8, raw$
   press_raw = (ASC(MID$(raw$,1,1)) << 12) OR (ASC(MID$(raw$,2,1)) << 4) OR (ASC(MID$(raw$,3,1)) >> 4)
   temp_raw  = (ASC(MID$(raw$,4,1)) << 12) OR (ASC(MID$(raw$,5,1)) << 4) OR (ASC(MID$(raw$,6,1)) >> 4)
   hum_raw   = (ASC(MID$(raw$,7,1)) << 8) OR ASC(MID$(raw$,8,1))
END SUB
' Temperature compensation
FUNCTION BME280_Temp(temp_raw)
   LOCAL var1, var2
   var1 = ((temp_raw / 16384.0) - (T1 / 1024.0)) * T2
   var2 = (((temp_raw / 131072.0) - (T1 / 8192.0)) * ((temp_raw / 131072.0) - (T1 / 8192.0))) * T3
   t_fine = var1 + var2
   BME280_Temp = (t_fine / 5120.0)*9/5+32
END FUNCTION
' Pressure compensation
FUNCTION BME280_Press(press_raw)
   LOCAL var1, var2, p
   var1 = (t_fine / 2.0) - 64000.0
   var2 = var1 * var1 * P6 / 32768.0
   var2 = var2 + var1 * P5 * 2.0
   var2 = (var2 / 4.0) + (P4 * 65536.0)
   var1 = (P3 * var1 * var1 / 524288.0 + P2 * var1) / 524288.0
   var1 = (1.0 + var1 / 32768.0) * P1
   IF var1 = 0 THEN
       BME280_Press = 0
       EXIT FUNCTION
   ENDIF
   p = 1048576.0 - press_raw
   p = (p - (var2 / 4096.0)) * 6250.0 / var1
   var1 = P9 * p * p / 2147483648.0
   var2 = p * P8 / 32768.0
   p = p + (var1 + var2 + P7) / 16.0
   BME280_Press = p
END FUNCTION
' Humidity compensation
FUNCTION BME280_Hum(hum_raw)
   LOCAL h
   h = t_fine - 76800.0
   h = (hum_raw - (H4 * 64.0 + H5 / 16384.0 * h)) * (H2 / 65536.0)
   h = h * (1.0 - H1 * h / 524288.0)
   IF h > 100 THEN h = 100
   IF h < 0 THEN h = 0
   BME280_Hum = h
END FUNCTION
' High-level read-all function
SUB BME280_Read temp, hum, press
   LOCAL tr, pr, hr
   BME280_ReadRaw tr, pr, hr
   temp = BME280_Temp(tr)
   press = (BME280_Press(pr) / 100.0)* 0.0295299830714+4.96
   hum = BME280_Hum(hr)
END SUB
' MAIN PROGRAM LOOP
BME280_Init
DO
   PRINT
 WEB MQTT PUBLISH "T ", str$(temp)), 1, 0
 WEB MQTT PUBLISH "H ", str$(hum)), 1, 0
 WEB MQTT PUBLISH "P ", str$(press)), 1, 0
   PAUSE 5000
LOOP
