Local Time 07:56 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWEB alphas a19+: now with added jokes (i.e. HTTPS)
Posted: 11:16am 20 Feb 2023
V5.07.07a19
PicoMiteWebV5.07.07a19.zip
Dim buff%(512)
Dim b$= "GET /random_joke"
WEB open tls client "official-joke-api.appspot.com",443
WEB tls CLIENT REQUEST b$,buff%(),10000
WEB close tlS client
a%=LInStr(buff%(),"{")-1
If a%<>-1 Then
 LongString trim buff%(),a%
 'LongString print buff%()
 Print Json$(buff%(),"setup")
 Print Json$(buff%(),"punchline")
EndIf
I have now implemented TLS which is the technology behind making HTTPS requests. This is HEAVY needing > 32KB of C heap memory to handle the certification and encryption and has reduced the variable memory to 80Kb as well as slowing MMbasic by about 20%.
However, I think this is pretty much essential as many websites now only respond on port 443 (TLS) so it is something we will have to live with to make the PicoMiteWEB properly useful. The PicoMiteWeb should therefore not be considered a general purpose port like the others but used only when you actually need web connectivity.
One more point that needs understanding:
The complexity of the web interfacing code means that it is unrealistic to handle all error conditions in a recoverable way (i.e. unwinding the stack and heap successfully). This will be very different from other versions of MMBasic and you will only be able to recover from errors with a reset
I will, of course, attempt to handle as many error conditions as I can but it is completely certain that there will be many more that can't be handled
LucV
Posted: 11:28am 20 Feb 2023
Thank you !!!
Luc's tech Blog
LucV
Posted: 12:50pm 20 Feb 2023
I can't help it. I keep experimenting and keep running into problems.
Here is an example of an api that works in the browser
http://api.coindesk.com/v1/bpi/currentprice.json
Tranlated:
Dim buff%(512)
WEB ntp
Dim report$="/v1/bpi/currentprice.json"
Dim b$= "GET "+report$+Chr$(10)+Chr$(13)
WEB open tcp client "api.coindesk.com",80
WEB TCP CLIENT REQUEST b$,buff%(),10000
WEB close tcp client
This gives a bunch of HTTP errors:
> RUN
Connected(
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.or>
<HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859>
<TITLE>ERROR: The request could not be satisfied</TITLE>
</HEAD><BODY>c
<H1>400 ERROR</H1>U
<H2>The request could not be satisfied.</H2>
<HR noshade size="1px">
Bad request.r
Trying the HTTPS version gives no difference:
Dim buff%(512)
WEB ntp
Dim b$= "GET /v1/bpi/currentprice.json"
WEB open tls client "api.coindesk.com",443
My api for sending to Telegram gives also an error:
error writing data, err=-6[9] WEB tls CLIENT REQUEST b$,buff%(),10000
Error : write failed -6
Sorry to be a nuisance. But progress is being made. Take your time.
This is just for information.
I presume there are not many users playing with this. So it does not have to get a big priority on your end.
Luc
Luc's tech Blog
Posted: 02:42pm 20 Feb 2023
I can't realistically diagnose these unless you can somehow get me a listing of what the browser is sending - wireshark might do it
Posted: 10:08pm 20 Feb 2023
I am surprised that you were able to implement TLS.
It doesn't seem to have upset my server side testing and will come in handy for many users.
Luc's site seems to use CloudFront and I often hear programmers complaining about issues with CloudFront
atmega8
Posted: 11:01am 21 Feb 2023
Sorry for may be stupid Questions..
HTML / Json complete new World for me.
Can someone please explain what this "Json$" is doing, where it comes from, where it is / Documenation/Manual?
Something new inside mmbasic?
THX
Posted: 11:16am 21 Feb 2023
  Quote  Can someone please explain what this "Json$" is doing, where it comes from, where it is / Documenation/Manual?
See the cmm2 manual for details
atmega8
Posted: 11:51am 21 Feb 2023
Peter,
found it, understand it, Thank You.
JSON$(array%(),string$) Returns a string representing a specific item out of the JSON input stored in
the longstring array%()
Examples taken from api.openweathermap.org
JSON$(a%(), “name”)
JSON$(a%(), “coord.lat”)
JSON$(a%(), “weather[0].description”)
JSON$(a%(),”list[4].weather[0].description
pwillard
Posted: 06:42pm 27 Feb 2023
Hmmm...
I still can't escape the problem at boot time where I get:
Assigned Address: 192.168.1.224
ntp address 198.137.202.32
NTP FAILURE
Always with the NTP failure.
Posted: 08:47pm 27 Feb 2023
  pwillard said  Hmmm...
NTP FAILURE
Perhaps your network is blocking requests to NTP port 123. It might be diverting to your ISP etc and the pico may not like that.
pwillard
Posted: 09:24pm 27 Feb 2023
Yeah, it's weird the SECOND attempt always succeeds.
I've also been trying to collect some notes to use as a reference to PicoMiteWeb so I can start to use this new stuff effectively.
SmallBook
Posted: 09:53pm 27 Feb 2023
  pwillard said  Yeah, it's weird the SECOND attempt always succeeds.
If the second attempt always works, forget my suggestion.
Have you tried a few seconds delay before the NTP command?
My router always needs two attempts to connect which is a pain but not difficult to allow for in the code.
Hans
Posted: 01:46am 28 Feb 2023
NTP FAILURE
I had the exact same thing but then it just went away, don't know why.
Also is there a way to know the requesting ip address of my web page?
Hans ...
Edited 2023-02-28 11:50 by Hans
Andrew_G
Posted: 02:51am 28 Feb 2023
@pwillard,
Your SmallBook is fantastic. I've scanned it briefly and have now started to read it more thoroughly.
It is just what I was hoping 'someone' would do.
May I suggest (unless others suggest otherwise) that you start a new thread because it might otherwise get lost in a sea of updates.
Well done,
Andrew
Andrew_G
Posted: 12:22am 03 Mar 2023
Peter (or maybe someone else)?,
"WEB NTP xx" is fantastic - it even sets DATE$, TIME$. Thanks.
What does it do with daylight saving time (DST)?
I assume that we adjust xx accordingly - is that so?
Cheers,
Andrew
Edited 2023-03-03 10:22 by Andrew_G
Posted: 12:52am 03 Mar 2023
  [ said  QUOTE=Andrew_G
Yes,
DST is too political to be easy. The date formulae is subject to the whim of our political masters (a frightening thought).
The quandary we have is, you can't calculate DST until you know the date. This prevents you changing the UTC offset before calling WEB NTP.
I am considering, getting the date assuming no DST then check the date to see if it needs adjusting. If so get WEB NTP again with the adjusted offset so, from then on NTP keeps the time until the next change in time zone.
If your system is running 335 days a year, you will need a daily(?) check to see if the UTC offset needs adjusting.
We have few weeks to get the code sorted out.
Might be easier to move to Queensland...
Edit
DIM dst
DIM Tzone = 10
dst = 1
WEB ntp Tzone+dst
PRINT time$
dst = 0
WEB ntp Tzone+dst
PRINT ti9me$
RUN
ntp address 162.159.200.123
got ntp response: 03/03/2023 12:04:39
12:04:39
got ntp response: 03/03/2023 11:04:39
11:04:39
Variables are OK so you just need to calculate DST or not.
Edited 2023-03-03 11:09 by TassyJim
Andrew_G
Posted: 01:20am 03 Mar 2023
Thanks Jim,
That makes sense.
I've got some code (somewhere) that checks the date and time and gives DST = 0 or 1.
There is an hour each year where it and I get confused.
Found it here . It triggered the discussion about how best to exit nested Do/Loops.
(I'm playing with two Picos (one normal, one W; for Mick and myself.
It gets the OpenWeather data on one and sends it by serial to the other for display with GUI on an LCD. So far so good.)
Cheers,
Andrew
(Queensland is OK for a few months and Tassie is not bad either . . .)
Edited 2023-03-03 11:29 by Andrew_G
Posted: 02:19am 03 Mar 2023
' Tassyjim - March 2023
DIM Tzone = 10
WEB ntp Tzone
PRINT TIME$
WEB ntp Tzone+dst()
PRINT TIME$
FUNCTION dst()
LOCAL aprstart, octstart, dst1, dst2, dateNow$
dateNow$ = DATE$
daynumnow = EPOCH(datenow$+" 00:00:00")/86400
aprstart = EPOCH("01-04-"+MID$(dateNow$,7,4)+" 00:00:00")/86400
dst1 = 3-(aprstart MOD 7)
dst1 = aprstart+dst1 ' first sunday in april in current year
octstart = EPOCH("01-10-"+MID$(dateNow$,7,4)+" 00:00:00")/86400
dst2 = 3-(octstart MOD 7)
dst2 = octstart+ dst2 ' first sunday in october in current year
PRINT DATETIME$(dst1*86400) ' for debug
PRINT DATETIME$(dst2*86400)
IF daynumnow < dst1 OR daynumnow >= dst2 THEN ' swap for northern hemisphere
dst = 1
ELSE
dst = 0
ENDIF
END FUNCTION
hard coded for Australia
Andrew_G
Posted: 06:08am 03 Mar 2023
Hi Jim,
I guess I can stop packing my bags for Queensland then.
Thanks,
Andrew
Pluto
Posted: 09:09am 03 Mar 2023
Thanks TassyJim. It will become a popular piece of code for many Pico W programs.
For the nothern hemisphere I just swapped these
dst = 0 'south=1, north=0
ELSE
dst = 1 'south=0, north=1
/Pluto
