Local Time 05:28 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicomiteWeb problem with TCP CLIENT REQUEST
LucV
Posted: 02:43pm 19 Feb 2023
I hate to admit it but I have a problem with web requests. I genuinely think it is my fault but I just can not find the fault.
I have a test account at Thingspeak and there is a value on a field. You can get that with the next api call:
http://api.thingspeak.com/channels/1841798/fields/1.json?results=2
If you paste that in your browsers URL field you will get the data containing fields with test temperatures.
So I tried to convert that to PicomiteWeb and I keep getting ar error. Can anyone point me in the right direction ??
Dim buff%(512)
WEB ntp
Dim report$="/channels/1841798/fields/1.json?results=2"
Dim b$= "GET"+report$+Chr$(10)+Chr$(13)
WEB open tcp client "api.thingspeak.com",80
WEB TCP CLIENT REQUEST b$,buff%(),10000
WEB close tcp client
Print Json$(buff%(),channel())
Print "Weather for " + Json$(buff%(),"name")
Print "Temperature is ",Val(Json$(buff%(),"field1"))
Print "Pressure is ",Json$(buff%(),"main.pressure")
What i did try is to leave the "GET"+ out and that did not work.
I also tried to put the / at the end of "api.thingspeak.com" to no avail.
BTW I do have a connection as the time is fetched from the NTP server and then
ntp address 94.228.220.14
got ntp response: 19/02/2023 14:41:06/
tcp address 52.204.34.129r
Connected
[9] Print Json$(buff%(),channel{})1
Error : Invalid JSON data
This is what I get.
Any thoughts ???
EDIT:
I am on PicoMiteWEB
> print (MM.Ver)
5.070718
Luc
Edited 2023-02-20 00:47 by LucV
Luc's tech Blog
Posted: 03:12pm 19 Feb 2023
You get a space after the GET. That then gets the data successfully. The json decoding isn't right but I'll leave that for you
Dim buff%(512)
WEB ntp
Dim b$= "GET "+report$+Chr$(10)+Chr$(13)
Print b$
LongString print buff%()
' good so far
LucV
Posted: 04:18pm 19 Feb 2023
Like I said: I genuinely think it is my fault !!!!
Missing a stupid space......
Thank you very much !!!!
Works as a charm.
For anyone interested I use JSONPATHFINDER for decoding JSON strings:
https://jsonpathfinder.com/
Thanks again.
Luc
Edited 2023-02-20 02:20 by LucV
Luc's tech Blog
LucV
Posted: 09:35pm 19 Feb 2023
Sorry to be a PITA but I still run into some trouble with other sites.
Yes: Thingspeak works like a charm and so does Dweet (for those that know the service). If anyone is interesetd I will post how to send data to Dweet and how to retrieve it. Dweet is a free service.
However.
I presume HTTP and no HTTPS ..........
That locks out a lot of api's like Telegram
I also presume GET and no Post ........
That also locks out some api's like Pushbullet etc.
Any idea why the joke API does not work. It is a stupid service but it gives me a hint on how to adress api's.
The general api is:
http://official-joke-api.appspot.com/random_joke
Put this in your webbrowser URL and you will get a random joke.
However:
Dim buff%(512)
WEB ntp
Dim report$="/random_joke"
WEB open tcp client "official-joke-api.appspot.com",80
Gives an error. HTTP/1.0  404 Not Found
And I have a home automation system: Domoticz
Dim buff%(512)
WEB ntp
Dim report$="/json.htm?type=devices&rid=2662"
Dim b$= "GET "+ report$+Chr$(10)+Chr$(13)
WEB open tcp client "192.168.1.66",8080
Here also an error rises.
HTTP/1.1 400 Bad Request
Would that be because the portnumber is 8080.
I know this is difficult if you do not own a Domoticz system yourself......
Typing the URL in the browser gives me a JSON feedback with all data about my local thermometer.
I know, I know a lot of questions. I hope someone can give a hand.
Luc
Luc's tech Blog
Posted: 10:43pm 19 Feb 2023
  LucV said  Sorry to be a PITA but I still run into some trouble with other sites.
Thanks for contributing.
  LucV said  I presume HTTP and no HTTPS ..........
Give Peter time, he's getting there :)
  LucV said  I also presume GET and no Post ........
Oh, same comment.
  LucV said  Any idea why the joke API does not work. It is a stupid service but it gives me a hint on how to adress api's.
The general api is:
Yes but your sample effectively connects first to just http://official-joke-api.appspot.com and that site does something reasonable but in this case unwanted (try it in a browser).
LucV
Posted: 09:05am 20 Feb 2023
John,
I made a mistake in my program by leaving out a space. I would not be surprised if I made more mistakes. Therefore I was not sure if HTTPS or POST were already implemented. Peter did not mention this in his posts about the new Picomite web version. It was meant as a question but it sounded pushy. I apologise for that.
You are right about the Joke site. It does something strange and then shows the JSON data. I did not see that.
I am coming a long way and have been programming in C++ and MicroPython on several microcontrollers (ESP8266, ESP32 and Pico). On MicroPyrhon the Joke API did not pose a problem. So I thought it was a problem on my side not understanding the syntax.
Thanks.
Luc
Luc's tech Blog
