Local Time 05:28 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to send control characters in hex
Canada_Cold
Posted: 09:43pm 18 Feb 2023
I’m programming a picomite to communicate to another processor via the com1 and send control characters in hex.  I’ve tried Print #1, CHR$(0A), CHR$(0D) but that gives me an error msg.
I did do a search on the manual, but did not find anything re sending hex characters.  Any help would be great.
Plasmamac
Posted: 09:54pm 18 Feb 2023
A = 10 so send chr$(10) and so on
Plasma
Posted: 10:06pm 18 Feb 2023
You need to use an &h prefix, it's in the manual somewhere:
Print #1, CHR$(&h0A), CHR$(&h0D)
Posted: 10:08pm 18 Feb 2023
If you want to send actual hex codes then send CHR$(&H0A).
ElectroPI
Posted: 10:18pm 18 Feb 2023
Just remember what happens with the PRINT command. If you print variables and put commas in between then the command inserts spaces between the numbers printed. I haven't tried it with control characters but I assume the same. So you should use semi-colons instead.
So let's say you need to send ESC followed by the characters S1 followed by cr then lf, the command would be
PRINT #1, CHR$(27);"S1";CHR$(13);CHR$(10);
Of course the 27, 13 & 10 could be replaced with &H1B, &H0D and &H0A.
Note the ; at the end of the line to suppress sending an extra cr/lf.
Canada_Cold
Posted: 11:02pm 18 Feb 2023
Thanks, that works great.
