Local Time 00:31 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite Incude external Files
AlexCesa
Posted: 09:18pm 18 Feb 2023
Goodmorning all
Is possible to include external files in MicroMite Basic ?
Thank you in advance
Posted: 09:32pm 18 Feb 2023
As far as I know only the Pico WiFi can include HTML and image files etc. for uploading, but not components of the MMBasic program.
Posted: 10:14pm 18 Feb 2023
Are you asking:
If you can #INCLUDE one source file within another? That's currently only available on the CMM2, MMB4W and MMB4L
or:
If you can access external assets, e.g images, CSV files, JSON ? In which case you just need a 'mite with an SD card or the PicoMite's flash file system.
AlexCesa
Posted: 12:53pm 19 Feb 2023
  phil99 said  As far as I know only the Pico WiFi can include HTML and image files etc. for uploading, but not components of the MMBasic program.
Thank you ... i mean INCLUDE other files of source code but it seems isn't possible
AlexCesa
Posted: 12:55pm 19 Feb 2023
  thwill said  Are you asking:
or:
Thank you TOM
I mean the 1st... i'm working on RPI Pico with Geoff firmware and it seems not possible
Posted: 01:09pm 19 Feb 2023
  AlexCesa said  Thank you TOM
Correct, I use a transpiler/preprocessor (running on MMBasic for Linux) to stitch together multiple files into a single .bas to run on the PicoMite.
In theory the transpiler can run on the PicoMite but I'm waiting for Peter to update the firmware with the support for command line arguments that I authored. He's been a bit busy recently though .
Posted: 07:48pm 19 Feb 2023
  thwill said  a transpiler/preprocessor (running on MMBasic for Linux) to stitch together multiple files into a single .bas to run on the PicoMite.
Good enough for now.
