Local Time 05:28 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need help with Telnet activation under Win10
Frank N. Furter
Posted: 12:51pm 16 Feb 2023
First: I have NEVER worked with Telnet.
- I have WLAN enabled (can see the neighbor's network).
- Under Windows Features I have enabled Telnet
- Raspberry Pico W was flashed with "2023-02-15_193513_PicoMiteWebV5.07.07a16" and
"OPTION TELNET CONSOLE ON" was executed
- Raspberry Pico W hangs on separate power supply and flashes
- When I enter "telnet 192.168.1.111" in the console, I get the error message:
"Could not connect to host, on port 23: connection error"
Also when I start TeraTerm (with the INI from Peter) I get the error message: "Connection timed out".
What am I doing wrong???
THANKS!
Frank
atmega8
Posted: 01:41pm 16 Feb 2023
Frank, can you PING the Pico ?
Disable the Windos Firewall globally.
You are shure about the correct IP?
Look at your DHCP Server.
atmega8
Posted: 01:42pm 16 Feb 2023
Please use Putty.....
My 1. Choice
Posted: 02:03pm 16 Feb 2023
Frank
You need to enable wifi
OPTION WIFI ssid$, password$
Then when the Pico boots it will tell you its address. 192.168.1.111 is just the address my pico uses
Michal
Posted: 02:06pm 16 Feb 2023
Or ask:
? mm.info(ip address)
Michal
atmega8
Posted: 02:29pm 16 Feb 2023
This works for me:
option list
PicoMite MMBasic Version 5.07.07a16
OPTION WIFI pabu19, *****************
> OPTION TCP SERVER PORT 80
Connected 192.168.178.36
Starting server at 192.168.178.36 on port 80
Frank N. Furter
Posted: 06:28pm 16 Feb 2023
Ok, I think I'm missing any basics here - can someone give me a step-by-step guide for dummies? (I have no experience with network...    )
I'm desperately searching the manual - how can I force a reboot again???
Frank
twofingers
Posted: 06:41pm 16 Feb 2023
  Frank N. Furter said  - When I enter "telnet 192.168.1.111" in the console, I get the error message:
Hello Frank,
First connect the Pico to the network with >OPTION WIFI "your ssid", "password"<.
After the reboot you will get the IP address that you need to use for Teraterm.
Sorry, I'm still using Win7.
Michael
... wird schon!
EDIT:
  Frank N. Furter said  I'm desperately searching the manual - how can I force a reboot again???
Power off/on? (USB-Hub with switches)
Edited 2023-02-17 04:46 by twofingers
The lone and ...
Frank N. Furter
Posted: 06:48pm 16 Feb 2023
Hi Michael,
first stupid question: Do I have to determine the SSID and the PASSWORD?
Frank
...ich hoff's... (I hope so...)
Posted: 07:05pm 16 Feb 2023
  Frank N. Furter said  Hi Michael,
Frank
Commonly a label on your router.
(Or look in your OS settings if using WiFi.)
Frank N. Furter
Posted: 07:13pm 16 Feb 2023
Hi John,
I think I understand.
I assumed that DIRECTLY from my computer can access it. So I DO NOT need to activate the computer's WiFi but the WiFi of the router to which the computer is connected???
Frank
Edited 2023-02-17 05:16 by Frank N. Furter
twofingers
Posted: 07:15pm 16 Feb 2023
  Frank N. Furter said  first stupid question: Do I have to determine the SSID and the PASSWORD?
SSID = your network/Wifi name.
Password = Your Wifi password.
The lone and ...
twofingers
Posted: 07:16pm 16 Feb 2023
  Frank N. Furter said   So I MUST not activate the WLAN of the computer but the WLAN of the router to which the computer is connected???
Correct!
Edited 2023-02-17 05:17 by twofingers
The lone and ...
Frank N. Furter
Posted: 07:20pm 16 Feb 2023
Ok, then I will have to activate a separate WLAN and connect my computer to this router. My "normal" WLAN is too far away here...
Frank
Posted: 07:25pm 16 Feb 2023
  Frank N. Furter said  Ok, then I will have to activate a separate WLAN and connect my computer to this router. My "normal" WLAN is too far away here...
Frank
Ah. I guessed you'd have WiFi within range of your Pico W.
Frank N. Furter
Posted: 08:14pm 16 Feb 2023
MANY THANKS TO ALL OF YOU FOR YOUR HELP!
No sooner do you do it right, than it works!
I have now connected a separate router with activated WLAN to my computer, read the SSID from it and entered it together with the WLAN password into the PicoMite.
Frank
