Local Time 23:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb alphas a14+, now with added Telnet
     Page 1 of 5
Posted: 12:37pm 14 Feb 2023
V5.07.07a14
PicoMiteWebV5.07.07a14.zip
New command
OPTION TELNET CONSOLE ON/OFF/ONLY
When set to ON or ONLY you can Telnet to the PicoMiteWEeb on port 23. You are still able to set up and run an HTTP server on port 80 (OPTION TCP SERVER PORT 80)
If set to ON console I/O will be available on either the USB port, the serial port or both as well as via Telnet.
If set to ONLY then the Telnet connection will be the only console port
Also in this release the number of connections is increased to 8 (untested)
The Telnet console is OK although you will see slight hesitation in single character echo (there is a lot going on to transfer 1 character). Transfer of multiple characters in the editor or the LIST command is very fast.
Don't ask how to configure Telnet on Linux/Mac etc. I don't know (or care?). It works well with teraterm on windows
Known issues.
I can't get very long transfers via AUTOSAVE to work. Shorter ones are fine
XMODEM not yet implemented
Edited 2023-02-14 22:40 by matherp
Frank N. Furter
Posted: 12:51pm 14 Feb 2023
Ok, now it's time that I also buy a Raspberry Pico W!
Thank you very much!!!
Frank
Posted: 01:56pm 14 Feb 2023
On Linux, try putty (or puttytel), which is probably already installed, or install telnet (if it isn't).
(I don't have anything currently on which I can test telnet protocol.)
Posted: 02:44pm 14 Feb 2023
This is super. Now fully remote PicoMiteWeb. Just the ticket.
homa
Posted: 04:45pm 14 Feb 2023
GOLD!
How is the weather? ;-)
Thank you for realizing the idea. You really do a great job.
homa
Posted: 05:14pm 14 Feb 2023
  matherp said  V5.07.07a14
What is your TeraTerm configuration? I don't get the commands displayed, but only after the Enter key. If I turn on the local echo, the command comes as output only after the Enter key.
An EDIT calls the editor, but ESC does not terminate it. The other keys F1, F2, ... do not work either :-(
All console commands work so far, with the above limitations.
Putty helps only conditionally. There I get a ^C to exit the program after a RUN. Enter then helps and I am back in the console.
Somehow I can't find the right TeraTerm setting to use the editor. Does anyone here know the correct settings and can help me?
Posted: 05:22pm 14 Feb 2023
TERATERM.zip
Michal
Posted: 06:03pm 14 Feb 2023
It also works with PuTTy.
Michal
Posted: 06:15pm 14 Feb 2023
Thank you for the TERATERM.INI file. In it, are the HOSTs specific to your system? Are they something we can delete?
Posted: 07:06pm 14 Feb 2023
One more version
PicoMiteWebV5.07.07a15.zip
Autosave now works over Telnet- use an inter-line wait of 20mSec
Teraterm/Setup/Additional settings/Copy and Paste/Paste delay per line
XMODEM works over telnet BUT.....
It can only support up to 254 blocks of 128 characters
It will fail in either direction if the checksum works out to be 255 (-1)
It doesn't appear I can do anything about this unless I can get TCP to run in raw mode.
Supported speeds for PicoMiteWeb are 64MHz to 264MHz. I find 256MHz completely reliable
  Quote  Are they something we can delete?
Yes, of course. Just connect to the address of your Pico
Edited 2023-02-15 05:12 by matherp
Amnesie
Posted: 07:18pm 14 Feb 2023
Just impressive! The only problem I have is I don't know where to start learning all this.. First the whole cool PIO and logic analizer stuff and now the Pico goes online...
Greetings
Daniel
atmega8
Posted: 07:33pm 14 Feb 2023
Fuc** Peter, you are ingenious!
How cool ist this?
Great, really great, Thank you very much!
Michal
Posted: 07:47pm 14 Feb 2023
Hi Peter
Thanks for the telnet.
Is it possible to impose your own IP address, mask(, gateway and DNS)?
And makes them permanent.
MichaƂ
Edited 2023-02-15 05:51 by Michal
Posted: 07:53pm 14 Feb 2023
  Quote  Is it possible to impose your own IP address, mask(, gateway and DNS)?
No. The PicoMiteWeb expects to be on a local network with a router providing all services. If you need a fixed IP address then just allocate it to the MAC address in the router.
And, for the avoidance of doubt, The PicoMiteWeb will always be in station mode
Michal
Posted: 08:11pm 14 Feb 2023
Hi Peter,
Wouldn't it be possible to at least lock the configuration? (To make sure that the remote station will always have a fixed IP without using DHCP)
The FOR NEXT test slowed down again between a14 and a15.
Michal
Michal
Posted: 08:45pm 14 Feb 2023
I have just compiled a simple telnet client in Delphi11 and the ISC library.
Maybe it will be useful to someone.
MATelnet_20230214.zip
Michal
bigfix
Posted: 08:52pm 14 Feb 2023
  Quote  No. The PicoMiteWeb expects to be on a local network with a router providing all services
This is not so easy in quite a few networks
IOT Devices are often in a separate subnet with their predefined addresses
You do not want to fiddle around with router setups based on HW addresses whenever something gets changed
About every device I ever configured had the option for fixed Network setup
JanVolk
Posted: 09:03pm 14 Feb 2023
Peter,
Problem with the latest version.
Option list had to be filled in again
After filling in the i2c bus worked correctly and the spi bus no longer worked?
> OPTION LIST
PicoMite MMBasic Version 5.07.07a15
OPTION SYSTEM I2C GP4,GP5
OPTION COLOR CODE ON
OPTION DISPLAY 40, 90
OPTION SDCARD GP17
OPTION RTC AUTO ENABLE
> A:
> files works fine
>B:
> FILES
Error : SD Card not found
Jan
Posted: 10:01pm 14 Feb 2023
MMEdit terminal seems to talk to it OK but there is a problem with the file manager.
XMODEM works but does not conclude reliably. The file list is OK provided there are not too many files to list.
Both problems look like a timing issue that I will track down in time.
The usual "load and run" program transfer seems to be reliable.
They take 10 times longer than USB but will be much quicker than removing a device from service (up a gum tree) to update software!
JanVolk
Posted: 10:08pm 14 Feb 2023
Sorry I just discovered problems with my Maker Pi Pico board.
Perhaps the contacts of the SD card holder are the cause?
Get a follow up.
And the language errors in the option list are the cause of google translate.
Another problem is that since January 31, when I joined the forum, my translation in google doesn't work anymore and only for this site, so I have to do everything manually.
Does anyone have the same experience or a solution? Already sent an email to the system administrator but have not yet received a reply.
Jan
     Page 1 of 5
