Local Time 00:31 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite VGA source
Mark
Posted: 09:51pm 13 Feb 2023
I see that there is a separate GitHub repo PicoMite-VGA-Edition for PicoMite VGA, but I also see comments in the main repo PicoMite about VGA.
Can PicoMite VGA be built from the main PicoMite repo?
Thanks,
Mark
disco4now
Posted: 10:03pm 13 Feb 2023
The readme in the VGA repository explains it. The VGA repository just contains the changes you need to make to build the VGA from the main repository.
PicoMiteVGA V5.07.07b18
This repository contains the files needed to build the PicoMite VGA Edition
Use all the files from the PicoMite repository with the exception of gui.c, gui.h, touch.c, touch.h, and CMakeLists.txt
Then build with the two additional files here and the VGA version of the CMakeLists.txt build file
F4 H7FotSF4xGT
Mark
Posted: 12:25am 14 Feb 2023
Thanks, I saw that in the readme, but I don’t see how the three files can add VGA support by just adding them, so I think there must be some VGA related code already in the main PicoMite repo. And if that’s the case, why is there a separate repo, why can’t the main repo be compiled two different ways, with and without VGA support.
Mark
Posted: 07:40am 14 Feb 2023
  Mark said  ... if that’s the case, why is there a separate repo, why can’t the main repo be compiled two different ways, with and without VGA support.
I've wondered the same but I've only just started to dabble with the PicoMite firmware. One possible reason, and I may be completely off-base here, is that for all his talents Peter is not as cognizant with CMake as he could be. I'm sure that if you care to offer some appropriate changes to CMakeLists.txr then he will consider adapting his approach.
Edited 2023-02-14 18:05 by thwill
Posted: 10:22am 14 Feb 2023
  Mark said  I think there must be some VGA related code already in the main PicoMite repo.
Correct.
  Mark said  And if that’s the case, why is there a separate repo, why can’t the main repo be compiled two different ways, with and without VGA support.
Mark
It may be that Peter was in a hurry and that it could be changed if anyone cares enough.
(I hate CMake, but love make.)
Edited 2023-02-14 20:23 by JohnS
stanleyella
Posted: 11:20pm 14 Feb 2023
From Mark's remarks, I wonder why there's spi and i2c in vga picomite but no glcd display drivers except 2 or 4 line lcd.
It would be useful if you could use an ili9341 as a touch keyboard and its sd card reader with vga picomite imho. If you reclaimed kb clk and data, spi display with touch is still several pins though. just a thought. using a calibrated touch screen in mmbasic is novel.
Posted: 07:59am 15 Feb 2023
Probably not enough space in the memory to have both VGA *and* LCD drivers, Stan. I think Peter would have left everything in if he could as it would make support easier.  :)
