Local Time 05:41 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Mac for Programming PicoMite
Mark
Posted: 11:58pm 10 Feb 2023
If anyone is using a Mac for programming the PicoMite, I have created a Mac Terminal setup (attached) that in conjunction with Minicom improves the interface to the PicoMite including the built-in editor. Most of the editor navigation keys work, the only one I couldn't figure out was INS, so I have to use ^N. The terminal also supports some of the high (> 128) characters so you can draw boxes on the screen.
I use the command line below to start Minicom
minicom -c on -L -b 115200 -D <your device>
I hope this helps you. I welcome any comments.
MMBasic.terminal.zip
