Local Time 00:51 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : testing analog and atari joysticks
RicM
Posted: 02:12am 03 Feb 2023
Dear Members,
Has anyone done a simple test program for analog and atari style joysticks
RicM
Posted: 07:42am 03 Feb 2023
Hi RicM,
Forum member "thwill" has written a game controller interface in MMBasic.
It was tailored to the GAMEpicoVGA board, but uses common MMBasic instructions.
Contact him (PM), he may be able to help you.
On the GAMEpicoVGA board you can simply plug these controllers in.
On a different platform you probably can use the code, but have to wire the controllers yourself.
Posted: 07:57am 03 Feb 2023
PicoGAME is designed to work with various switch-type joysticks and a game pad. There is info on them in the Construction pack for it. You can find that by following the link in my sig.
I wrote a test program for it, but I'm struggling to find it now. It tested both game ports and various joysticks, including the analogue inputs. This might be it
Edited 2023-02-03 18:13 by Mixtel90
