Local Time 05:55 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite: RTC error stop program
grroel.tech
Posted: 06:54pm 31 Jan 2023
Hello,
I have a program that reads the temperature and humidity from a DHT22 module and displays the values on an ILI9488W display in an infinite loop, but when exactly 3600 seconds have elapsed the program terminates in the second line "Pause 500" with error "RTC is not responding".
This is the program:
'temp Humid display
Colour RGB(255,255,255),RGB(0,0,0)
CLS
antTemp = 0 : antHumidity = 0
 Text 10,280,Str$(Timer/1000),"LT",3,1,RGB(255,255,255),RGB(0,0,0)
 Circle 420,40,10,,,RGB(255,0,0),RGB(255,0,0)
 Bitbang humid GP28,Temp,Humidity
 Pause 500
 If antTemp <> temp Then
   Text 10,10,Str$(Temp),"LT",6,2,RGB(255,0,0),RGB(0,0,0)
   antTemp = Temp
 EndIf
 If antHumidity <> Humidity Then
   Text 10,140,Str$(Humidity),"LT",6,2,RGB(0,255,0),RGB(0,0,0)
   antHumidity = Humidity
 EndIf
 Circle 420,40,10,,,RGB(0,0,0),RGB(0,0,0)
 Pause 500
Loop
End
What happens? Why does the program terminate after this time if the DO loop is supposed to ... LOOP is never supposed to stop, and is there some kind of limitation?
Thank you,
Gerardo R. Roel,
San Fernando, Cadiz, Spain.
Posted: 06:57pm 31 Jan 2023
You have OPTION RTC AUTO ENABLE set and the RTC either isn't there or isn't responding
grroel.tech
Posted: 10:49am 01 Feb 2023
Hello,
A disconnected cable from the RTC module was the culprit. I didn't realise the clock wasn't working. Simple.
Thank you very much for your quick response.
Gerardo R. Roel
