Local Time 05:55 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4L: need examples specifying types in the non-suffix way
Posted: 09:42am 30 Jan 2023
Hi folks,
It occurred to me when taking the kids to school this morning that all my examples and test code for MMB4L specify types using suffix syntax, i.e. i%, f!, s$.
Does anyone have / can anyone point me to some significant pieces of console-only (no hi-res graphics, no additional hardware requirements) MMBasic that use the other two type syntaxes, e.g.
DIM INTEGER nbr(50)
DIM name AS STRING
Thanks in advance,
Posted: 11:05am 30 Jan 2023
Maybe FruitOfTheShed has stuff.
Posted: 11:09am 30 Jan 2023
  JohnS said  Maybe FruitOfTheShed has stuff.
I'm sure it does John, I was just being lazy . I guess I was hoping that if there as someone interested in using MMB4L they might be prepared to do some of the spade-work.
As it happens, I have broken the alternative syntax - probably a simple fix for this evening.
Posted: 11:50am 30 Jan 2023
I'd done a search of files I've kept but they all seemed to break your requirements e.g. had graphics or used hardware -- hardly a shock for MMBasic & TBS.
Posted: 12:37pm 30 Jan 2023
Thanks John.
Wasn't there some sort of celestial calculator/clock that gets posted about occasionally, I believe Peter might even have used it for testing ... I can't find it now.
Posted: 12:55pm 30 Jan 2023
I've used both of those now and again, especially DIM INTEGER a,b,c,i,j,x,y  That's almost a standard command for me and variants of it turn up a lot. Apart from $ I very rarely use a type suffix as I can't be bothered typing them.  :)
Posted: 03:31pm 30 Jan 2023
  thwill said  Wasn't there some sort of celestial calculator/clock that gets posted about occasionally, I believe Peter might even have used it for testing ... I can't find it now.
Sounds like the one that uses triangle, circle, etc
Edited 2023-01-31 01:32 by JohnS
