Local Time 06:08 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2040 DMA Hack Makes Another ‘CPU Core’
lew247
Posted: 07:05am 21 Jan 2023
Saw this here
Posted: 08:05am 21 Jan 2023
A "because it can be done" project. :)  Very neat but probably of very limited use.
Posted: 08:30am 21 Jan 2023
  Mixtel90 said  A "because it can be done" project. :)  Very neat but probably of very limited use.
there may be the odd niche where it could be useful. for instance, if you wanted a small auxiliary processor to handle USB communications with zero interaction with the two main cores. a bit like how the 16F1455 processor handles USB for the MX170/470 on Explorer boards.
rob   :-)
Posted: 11:42am 21 Jan 2023
Good grief!
How... er, bizarre?
Posted: 11:54am 21 Jan 2023
It goes to show the flexibility of the RP2040 architecture. I suspect this possibility wasn't part of the original design. Usually someone will find a way to make things do what they weren't intended to. :)
