Local Time 01:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ILI9341 + Picomite MMBASIC
asknik2022
Posted: 10:52am 20 Jan 2023
Can I change the orientation of the LCD without having to to use option reset each time
Posted: 11:21am 20 Jan 2023
You mean change it within a program? No, not in any straightforward way anyway.
asknik2022
Posted: 08:38am 21 Jan 2023
Worked it oput.
You have to use option lcdpanel disable via TeraTerm and then re enter with orientation that you want.
