OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1051
Posted: 09:18am 19 Jan 2023
Is the description of the PULSE command still accurate with the PicoMite given it has a much higher frequency?
The minimum is 5µs at 40MHz to 40µs at 5MHz
OA47
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382
Posted: 11:00am 19 Jan 2023
Current manual p115.
"For a pulse of less than 3 ms the accuracy is ± 1 µs. For a pulse of 3 ms or more the accuracy is ± 0.5 ms. A pulse of 3 ms or more will run in the background. Up to five different and concurrent pulses can be running in the background and each can have its time changed by issuing a new PULSE command or it can be terminated by issuing a PULSE command with zero for 'width'."
Edit Using a PIO program and maximum CPU speed you can make much shorter pulses. . Edited 2023-01-20 07:19 by phil99
