Local Time 01:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Format error
Chrisk
Posted: 07:59am 18 Jan 2023
Hi Guys
Can someone explain why I am getting this error.
I have used a similar line before with no problems
LCD 2, 1, format$(Ssum,"%3g") + " " + Mid$(Time$,1,5)
Error: FORMAT is not declared
Chrisk
Posted: 08:23am 18 Jan 2023
In case it's a specific glitch in the parser, does it work in a line more like
a$=format$(...)
panky
Posted: 08:24am 18 Jan 2023
Hi Chris,
What platform, what version of MMBasic and possibly a dump of OPTIONs?
Doug.
Posted: 09:58am 18 Jan 2023
Obviously the function FORMAT is not included in the version of MMBasic that you are using (check the user manual for that specific version).
Because there is no such built in function MMBasic then went looking for a user defined function called "format" and because that was not found it generated an error message to that effect.
Instead of FORMAT() use STR().  It works differently but can generate a similar result.
Chrisk
Posted: 03:25am 19 Jan 2023
Thank you Guys for your replies
I have a CMM using an older version of MMBasic and what I forgot is that the MMBasic is different for my Micromite Explore64 using MMBasic Version 5.0501
Used the STR() instruction without a problem.
Thanks again.
