Forum Index : Microcontroller and PC projects : Problem with "PLAY WAV" and PicoMite 5.070606
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153 |
Hi! I want to play a few WAV files in continuous loop for a future Halloween project. Unfortunately I get an error message after some playback time. The WAV are on the flash drive (PicoMite 5.070606). Option Explicit Dim WAVbusy As INTEGER Const TRUE=1 Const FALSE=0 Do WAVbusy=TRUE Play wav "WIZSIT.wav",IROUTINE Do Loop While WAVbusy=TRUE Pause 5 WAVbusy=TRUE Play wav "MUMSIT.wav",IROUTINE Do Loop While WAVbusy=TRUE Pause 5 WAVbusy=TRUE Play wav "WIZSIT.wav",IROUTINE Do Loop While Wavbusy=TRUE Pause 5 WAVbusy=TRUE Play wav "MINACT.wav",IROUTINE Do Loop While Wavbusy=TRUE Pause 5 Loop Sub IROUTINE WAVbusy=FALSE IReturn It works for some time, then I get this error message: Here are my WAV files: WAV.zip What am I doing wrong??? Is there any way to make it easier to query for the WAV end??? THANKS! Frank |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
@Frank From manual Regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Do you think I should exchange IReturn for END SUB? I do not fully understand the text from the manual... Frank |
Yes. An interrupt routine is now a normal SUB so IRETURN isn't required. END SUB or EXIT SUB can be used as usual. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thank you both so much!!! Now it works as it should. The program now looks like this:Option Explicit Dim WAVbusy As INTEGER Const TRUE=1 Const FALSE=0 Do PlayWAV "WIZSIT.wav" PlayWAV "MUMSIT.wav" PlayWAV "WIZSIT.wav" PLAYWAV "MINACT.wav" Loop Sub PlayWAV wav$ WAVbusy=TRUE Play WAV wav$,IROUTINE Do Loop While Wavbusy=TRUE End Sub Sub IROUTINE WAVbusy=FALSE End Sub MANY THANKS!!! Frank |
Cool! and "guten Rutsch!" (happy New Year!) ![]() ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Dito!Frank |
