Local Time 06:49 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic valid criteria
OA47
Posted: 05:54am 22 Dec 2022
Is this type of expression valid in MMBasic:
IF 0 <= Variable <= 10 Then
OA47
Posted: 06:07am 22 Dec 2022
No
If you try you will get caught up in comparing the result of a comparison with the other value/expression.
If (0 <= variable) and (variable <= 10)
I am not sure if the brackets are required. I did experiment with that some time ago. Too many electrons flowed under the bridge since then...
You could do a function if there are a few to do,
OA47
Posted: 06:31am 22 Dec 2022
Thanks Jim. The program was accepting the code (I am not sure which variation of Basic I got it from) but I was getting unpredictable outcomes.
Merry Christmas
OA47
Posted: 09:02am 22 Dec 2022
select/case might be a fit for you - it has a close enough syntax to what you give above:
Select Case x
  Case 0 To 10
End Select
bit long-winded if you are doing just a single comparison tho'
also, consider Constrain(), that might fit what you are doing.
h
toml_12953
Posted: 03:16pm 22 Dec 2022
  OA47 said  Is this type of expression valid in MMBasic:
OA47
In many BASICs, the first part (0 <= Variable) will return a -1 if variable >=0 and a 0 if variable <0.
Then it will compare that result with 10.
Since both 0 and -1 are <=10 the branch will always be taken
Edited 2022-12-23 01:20 by toml_12953
