Local Time 06:49 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Counting Input Questions
DrifterNL
Posted: 03:37am 21 Dec 2022
Hi again,
What is the maximum frequency and minimum pulse length that can be used on a pin configured for counting to still get a reliable count?
Floating Point Keeps Sinking Me!
Back To Integer So I Don't Get Injured.
IanRogers
Posted: 08:47am 21 Dec 2022
Did you read this thread..
www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15380
Sorry can seem to make a link
Edited 2022-12-21 18:51 by IanRogers
I'd give my left arm to be ambidextrous
Posted: 01:45pm 21 Dec 2022
Short answer:
The picomite SETPIN gpx,FIN function
Up to 50kHz it is accurate error < 1%
Up to 200kHz you are looking at 2-3 % error
Up to 500kHz you have up to 20% error
It also depends on the CPU load. in example, if you have OPTION AUDIO set,the CPU can be more busy and faults get larger.
Edited 2022-12-21 23:46 by Volhout
Posted: 02:37pm 21 Dec 2022
Try V5.07.06b6 - accuracy much improved. Tested at 500KHz with CPU speed 378MHz.
DrifterNL
Posted: 03:03pm 21 Dec 2022
Hi all,
I'm actually asking about the SETPIN pin,CIN function, and how high the frequency and short the pulse can be before the picomite starts to miscount.
I'm using V5.07.05b15
Edited 2022-12-22 01:06 by DrifterNL
Posted: 03:14pm 21 Dec 2022
Use 5.07.06b6 it improves FIN, CIN, and PER
At base CPU frequency I've just tested with 200KHz and pulse width of about 40nS
CIN behaves the same as FIN
Edited 2022-12-22 01:16 by matherp
DrifterNL
Posted: 07:25pm 21 Dec 2022
Thanks for all the responses.
Looking at the posted frequencies and pulse width the PicoMite should easily count pulses that have a width of ~5ms and frequency of ~28Hz.
I'll be sure to update to the latest firmware.
