Local Time 00:52 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: what the monkey made
     Page 1 of 3
Posted: 01:51pm 19 Dec 2022
Hi folks,
I had planned to defer sharing until I had a schematic and maybe a video made, but I failed to be that patient:
Thanks to everyone who helped, even if they didn't know that they were, especially @Volhout (audio), @Mixtel90 (I borrowed the backpack schematic for much of the layout) and @Turbo46 (encouragement).
Apologies for the dreadful photo lighting / editing.
IanRogers
Posted: 02:15pm 19 Dec 2022
Looks really good..
On my pico system the pico is under the screen ( like the micromite backpack )  Just shows how versatile these things are..
Well done....
Ian
I'd give my left arm to be ambidextrous
Martin H.
Posted: 02:26pm 19 Dec 2022
a original Tomboy
hope you'll get PicoVaders running
Edited 2022-12-20 00:28 by Martin H.
'no comment
Posted: 02:29pm 19 Dec 2022
  Martin H. said  ... hope you'll get PicoVaders running
I did, it does .
Edited 2022-12-20 00:30 by thwill
Posted: 03:03pm 19 Dec 2022
With integrated NES controller... WAUW...
Nice work Tom !!
Looking at the pictures, I guess the battery is under the display, not leaving much room for the picomite...
When possible, show a video of the Bintendo Tomboy in operation...
Posted: 03:23pm 19 Dec 2022
Yay! I love it! :)
Especially good for a non-hardware bod. Congratulations. :)
Posted: 03:24pm 19 Dec 2022
  Volhout said  With integrated NES controller... WAUW...
An affectation, the Pico has enough GPIO that I could have just wired up the buttons directly.
  Volhout said  Nice work Tom !!
  Volhout said  Looking at the pictures, I guess the battery is under the display, not leaving much room for the picomite...
The battery is under the protoboard taped to the piece of foamboard that currently serves as the "enclosure". I think there is space under the screen to squeeze in the PicoMite, a micro-sd, the charger module and the amp module (once I've chosen one - the current "buzzer" setup is just a temporary expedient to "complete" this prototype) and then compact the whole device onto a 100x100mm PCB - my next step with the h/w once all the bits arrive.
  Volhout said  When possible, show a video of the Bintendo Tomboy in operation...
That's the plan, but I want to put in the extra effort to make a proper video (rather than a quick single-take recording) so as to potentially attract a wider audience.
Posted: 04:19pm 19 Dec 2022
When you said a 100x100 PCB I thought of my MachiKani layout...
Maybe a rehash of it is on the cards. :)
Posted: 04:30pm 19 Dec 2022
  Mixtel90 said  When you said a 100x100 PCB I thought of my MachiKani layout...
If I'm honest this is why I didn't discuss my project earlier and was loath to do so even now except for the little voice in the monkey's head that wanted to "show off" the tricks it had learnt ... I knew you could knock off a PCB faster than I could type the letters 'P', 'C', 'B' and was hoping to do it for myself   .
Posted: 04:49pm 19 Dec 2022
You're quite welcome to do so! :) I'll send you my SL6 file if you like and you can have a go at modifying it. It might give you a good start.
I'd suggest moving the display slightly further "up" the PCB, although you may need to find a thinner speaker.sounder to do so. An idea there might be to use one of the thin piezo elements (the flat ones) and glue it to either the bottom of the case or, if tracks allow, to the bottom of the PCB. The SD card might be able to go on the underneath of the PCB, underneath the Pico (which is surface mounted).
Getting the height of the display correct to fit the case will require a little thought.
EDIT
I think this needs:
a) a longer connector for the display in order to get it close enough to the box lid. It may be possible to use a through-hole PicoMite with this.
b) a daughter pcb on pillars to get the buttons close enough to the lid of the box.
c) the display moving "up" as far as reasonably possible to make more room for the buttons at the bottom.
d) as far as I can tell from looking at a box, it would be possible to fit the SD card holder under the PCB (but probably not the battery).
e) it *might* be possible to fit a SMD Pico under the PCB, which would make plenty of space under the display for the battery. I've not measured anything.
All of these ideas mean a (more or less) complete change of layout so there's plenty for you to do. :) Note though that at the moment the centre line of the display is very close to the centre line of the PCB and box so there's no need to change its horizontal position.
Edited 2022-12-20 05:17 by Mixtel90
Posted: 07:43pm 19 Dec 2022
Thanks Mick, I was (mostly) just kidding, I don't have a monopoly on this so knock yourself out, in any case my design is highly derivative of your work.
I'm intending to start from scratch using EasyEDA (which I have some familiarity with for schematics) and the only enclosure I'm worried about is a two layer PCB or acrylic "sandwich".
If/when I've cocked it up a couple of times I may defer to a helpful guru to design a PCB.
Posted: 08:20pm 19 Dec 2022
If you grab the Hammond drawing for the 1593 case you'll be able to use the same PCB size, notches and fixing centres for your PCB. That will make things a lot easier later should you decide to use a "proper" case.
I may not be doing much for a while yet. I have my record deck in pieces, undergoing a big upgrade and re-build. :)  Vinyl rules!
Hans
Posted: 10:56pm 19 Dec 2022
@thwill
Hi Tom;
Just received one of those displays (ILI9341). I bodged up the SD Card part and works great.
Do you have a schematic or just a list of Pico pins to the display connector you could please share?
I searched and while there was a huge discussion about ILI9488 not working, it only referenced the ILI9341 controller which has different pin designations.
A picture of the connections on my board;
Thanks in advance for any help from the group.
Hans ...
Posted: 11:07pm 19 Dec 2022
  Quote  Do you have a schematic or just a list of Pico pins to the display connector you could please share?
manual "Example LCD Panel Configuration"
Hans
Posted: 04:23am 20 Dec 2022
Thanks I knew I saw the details somewhere but I just could not remember where. Page 47 is exactly what I was looking for.
Again thanks Peter and a Merry Christmas to you and your loved ones .
Hans ...
Turbo46
Posted: 07:23am 20 Dec 2022
Hardly a monkey Tom.
I'd like to see a demo too. If you make a video I hope you can find something better for the sound than those buzzers.
I'll be very interested to see what other games you produce for it. I just may have to build one.
Turbo46
Posted: 07:43am 21 Dec 2022
@Volhout, I thought that you may like to design a filter especially to suit the Tomboy.
I have looked at the music and sounds that Tom uses and all of them are under 5kHz (the highest frequency on an 88 key piano is 4186Hz). There are no intentional harmonics as when a musical instrument is played I believe.
I believe that the PLAY SOUND is used to play sine waves but I see that 'TYPE O' and 'TYPE S' are used but I cannot find out their meaning in any manual.
Anyone?
  CMM2 manual said  PLAY SOUND which will generate an output based on a mixture of sine, square, noise, etc waveforms.
Maybe type O is 'off', type S is sine but I don't know? Can one channel have two or more types of wave form or do you use different channels for the different waveforms? I hope that type 'S' is not square wave because this post is largely meaningless.
For the digital amplifiers that he intends to use the best I can find is an input impedance of >22k. That would be less if he has the need for a volume control.
I would have thought that a simple two stage passive RC filter (12dB per octave) that begins to roll off at 5kHz with capacitive coupling to the amplifier input would be sufficient.
I'd be interested in your thoughts.
Posted: 08:04am 21 Dec 2022
Hi Tom,
The picomiteVGA manual shows your sound options...
I'll see what I can do for the filter/amplifier. Do you envision one of this digital amplifiers, and need a simple filter between pico and the digital amplifier ? Or do you want the whole circuit designed (including the amplifier).?
Turbo46
Posted: 08:25am 21 Dec 2022
Hi Volhout, It's me asking about the filter. I have discussed it with Tom and he is happy with my request.
He has ordered two different digital amplifier modules to try as far as I know.
Clearly I do not have the latest manual (I thought I did) but it's not in the CMM2 manual? Found it in the Draft PicomiteVGA manual thanks.
Posted: 08:37am 21 Dec 2022
  Quote  Clearly I do not have the latest manual (I thought I did) but it's not in the CMM2 manual?
Page 99 (Adobe page) of CMM2 manual as downloaded from Geoff's site
Edited 2022-12-21 18:39 by matherp
     Page 1 of 3
