Local Time 12:03 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Geoff's boat computer for the PicoMite - NO SOLDERING
Posted: 11:45am 03 Dec 2022
Using the Pico board with the Waveshare 2.8" display  and the Waveshare Pico GPS  it is possible to make Geoff's boat computer plug and play.
Pico compatible code
BoatComputerV6.zip
Changes to Geoff's code are minimal to match the Pico with one small but important functional change which is to accept GNRMC as well as GPRMC
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION AUTORUN ON
OPTION LCDPANEL ST7789_320, RLANDSCAPE,GP8,GP15,GP9,GP13
OPTION TOUCH GP16,GP17
GUI CALIBRATE 0, 3927, 195, -895, 650
OPTION SDCARD GP22
Edited 2022-12-03 22:50 by matherp
Turbo46
Posted: 11:40pm 08 Dec 2022
Probably the same setup would run Geoff's Super Clock as well?
lew247
Posted: 10:07am 10 Dec 2022
Peter am I right in thinking that this 3.5" would work the same as this one with picomite?
it says the driver is ILI9488
Posted: 10:38am 10 Dec 2022
  Turbo46 said  Probably the same setup would run Geoff's Super Clock as well?
Would it need some soldering, though?
Turbo46
Posted: 11:47am 10 Dec 2022
No soldering if the GPS is the time source. As far as I can see.
jaybek
Posted: 06:43am 13 Dec 2022
Then maybe run it on a RP2040-Plus  with a 105080 lipo 5000 mA battery and make it all portable?
#MeTo ZX81
Posted: 10:53am 13 Dec 2022
That might work - but just remember that the RP2040 Plus isn't a supported platform for MMBasic. There could just possibly be trip-ups.
circuit
Posted: 09:50am 19 May 2024
  matherp said  Using the Pico board with the Waveshare 2.8" display �and the Waveshare Pico GPS �it is possible to make Geoff's boat computer plug and play.
BoatComputerV6.zip
OPTION AUTORUN ON
OPTION SDCARD GP22
Such a tempting combination, I couldn't resist!  All assembled and programmed as instructed, but... as soon as the lower part of the screen is touched the program collapses with an error declaring that at line 151; pin GP17 was reserved at start up, which it was when TOUCH was set up.
Line 151:       SetPin gp17, OFF   ' no interrupts in the menus
This interrupt is reset in line 154 after the SetDetailMode subroutine is done.
Help?
Posted: 10:15am 19 May 2024
Try replacing the line with a setpin to an empty interrupt
SetPin gp17, INTL, NoOp
sub NoOp
end sub
palcal
Posted: 08:51pm 19 May 2024
Does the waveshare GPS come with antenna, it does not mention it on their web site.
Posted: 08:58pm 19 May 2024
  Quote  Does the waveshare GPS come with antenna, it does not mention it on their web site.
Mine did
circuit
Posted: 09:59pm 19 May 2024
Peter, thank you, that seems to work; program no longer crashes.
This makes me think, am I the only one who has built this configuration?  Otherwise why am I the only one flagging up that the program, as provided, crashes?
circuit
Posted: 10:01pm 19 May 2024
Mine did
As did mine.
okwatts
Posted: 11:41pm 19 May 2024
I did build this up some time shortly after Peter posted this. Mine seems to work as it should but I installed MMBasic version 5.07.04 at the time. I don't recall having any difficulty with it and I just dug it out and fired it up and it runs no problem. Also mine came with the antenna. Edit: Ordered directly from Waveshare.
Edited 2024-05-20 09:43 by okwatts
Frank N. Furter
Posted: 08:48am 16 Aug 2024
Hello everyone,
I am trying to get the project to work on a Waveshare 3.5" display display. This display has an ILI9488W chipset.
If I only plug in the PicoMite, the display works perfectly, if I plug in the GPS, the display remains black and GUI TEST LCDPANEL does not show anything.
WHY???
I have tried the last official firmware V5.08.00 and the current beta firmware V5.09.00RC5.
Here are my options:
PicoMite MMBasic Version 5.08.00
OPTION COLOURCODE ON
OPTION LCDPANEL ILI9488W, RLANDSCAPE,GP8,GP15,GP9,GP13
OPTION SDCARD GP22
Can anybody help me???
Frank
Frank N. Furter
Posted: 09:43am 16 Aug 2024
Ok, I have found the error!
The contacts that Waveshare used on the GPS are obviously too short!!!
In addition, too much solder was used, which led to the contacts making even worse contact.
An additional wire to VSYS solved the problem:
I also had to make the change in line 151 so that the program runs without errors...
Frank
