Local Time 05:00 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help needed to track down a fault.
OA47
Posted: 05:23am 27 Nov 2022
I have an ARMITE F4 board and screen that I am using to monitor some control lines and send and receive data to a star network of micromites via 433Mhz radio modules and a PC via a serial port/usb. The issue I have is that the F4 locks up at an interval that could be up to 10 days. The PC software keeps running as do all of the remote units. The screen on the F4 just freezes as does a console connection running at 9600 bps. I have a watchdog timer set in the software so the freezing is not enabling the watchdog to reset the software. Over the past months I have swapped out all the hardware including the F4, PC, USB-Serial modules and remote units. I have run the F4 from a power pack USB output as it is usually powered by the PC so I can use the Console port to monitor the software.
I am now out of ammunition can anyone suggest a way of diagnosing this situation?
OA47
Quazee137
Posted: 06:42am 27 Nov 2022
try a 2nd com port connected to a micromite. Send status of software at breaks points
in code. If the main status stops it can act as an external watchdog and reset the F4.
Log status to pc it may help locate where things break.
I use a mup micromite to debug new work. It has helped locate bugs (my errors) LOL.
Edited 2022-11-27 16:45 by Quazee137
OA47
Posted: 06:53am 27 Nov 2022
Thanks for the reply Quazee137 but I currently get debug reports to the console port which also locks up when the F4 locks up and does not describe any abnormality.
disco4now
Posted: 07:07am 27 Nov 2022
You could define an number of gui LEDs on the LCD Display. Initially set them all green and assign each one to monitor key parts of the program. At start of code of interest set it red, at completion set it green. e.g when COM port gets an interrupt set LED RED, when message is complete set Green. This may help located where in code the lockup occurs. e.g if same LED is Red each time it stops.
F4 H7FotSF4xGT
Posted: 07:23am 27 Nov 2022
Adding to that an SD card log might be useful. At a set of numbered points at key places in the program log the point number, time and the value of relevant variables.
That should at least indicate the last place in the program it was working, with the value of the variables showing what was going on at the time.
Posted: 07:45am 27 Nov 2022
Is there a watchdog running? Perhaps there should be, at least for testing purposes.
Posted: 08:11am 27 Nov 2022
As per Quazee137, use a second serial port with an external USB/UART rather than the console to monitor. The USB console is potentially the problem so eliminate it
Posted: 08:12am 27 Nov 2022
Ask Peter the memory addresses of c-stack and heap. Watch those 2 during operation. These variables show how much memory is consumed. These values constantly var, but you could have a memory leak, so they fill up.
It could be in the basic code, but could also be you are using a basic command incorrectly, or the command itself has a fault.
Not sure how many peop le run an F4 continuous with complex programs. Mine is a tetris game, that I play for 1 hour, then put it away...
Edited 2022-11-27 18:14 by Volhout
Posted: 09:04am 27 Nov 2022
is the USB connection provided by the F4 processor itself, or is there an external USB to serial bridge? i'm just wondering (if the F4 is handling the USB) if the USB stack on the F4 is crashing. and could the USB stack be disabling the watchdog hardware?
rob   :-)
Edited 2022-11-27 19:08 by robert.rozee
Chopperp
Posted: 12:22pm 27 Nov 2022
FWIIW, I've just had a similar problem with an F4 left running connected to a PC via USB while doing software mods & tests. It was locking up periodically.
OK when back on it's normal 5V plug-pack. I didn't have the time (or inclination) to find out why.
(I was sort of blaming MMEdit but that is probably a tad unfair...)
Brian
ChopperP
OA47
Posted: 07:49pm 27 Nov 2022
Thankyou for the suggestions. I do have a feeling about the stack for the console port causing the issue so it wont be too onerous to disable data feed to the console and see how that goes over the next couple of weeks.
OA47
Posted: 07:55pm 27 Nov 2022
Use OPTION SERIAL CONSOLE ON and then connect a USB/UART to PA11/PA12. That disables the USB but allows you to keep using the console via a normal serial port
OA47
Posted: 09:55am 28 Nov 2022
I was unable to make a console connection using PA11/PA12 after using OPTION SERIAL CONSOLE ON but did notice activity on COM1 which is used to communicate with the radio module. I turned off the monitoring to the USB com port to reduce the traffic and will see how it goes.
If I cannot overcome this issue I might consider using a 44 pin micromite/lcd and port the software over.
OA47
disco4now
Posted: 10:14am 28 Nov 2022
  OA47 said  after using OPTION SERIAL CONSOLE ON ... did notice activity on COM1 ...
OA47
Yes, OPTION SERIAL CONSOLE ON does place the console on COM1, PA09 and PA10.
PA11/12 are the USB console data connections.
F4 H7FotSF4xGT
OA47
Posted: 07:02am 06 Dec 2022
I have monitored the software running on the F4 Armite for a week, after restricting regular feeds to the USB/console and moving it to an always powered USB port, the software has not locked up but I did have to reboot the PC to get the USB port to talk to the Armite. I have programmed an uptime counter to display on the TFT and will monitor further.
OA47
OA47
Posted: 04:55am 28 Dec 2022
500 hours on the uptime monitor, so my current conclusion is that the console buffer or stack has possibly caused the unit to freeze.
Maybe see if it makes another 500 hours.
OA47
OA47
Posted: 04:42am 01 Mar 2023
The unit did not make another 500 hours   At 408 hours uptime the F4 screen is frozen and there are only the initial startup messages on the CONSOLE and no error messages. I have an EVENT.LOG file that saves a log of events to the SD card but there is no indication of abnormalities in the software the last entry is timed before the clock on the frozen screen. I am using the lab power supply to supply the F4 board.
Any suggestions?
OA47
