Local Time 01:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic: unhelpful syntax issue with CASE IS
Posted: 07:25pm 20 Nov 2022
Hi Peter & Geoff,
Reproduced with CMM2, PicoMite (, MMB4L) and presumably also present in MMB4W:
> list "case_is.bas"
Option Explicit On
Dim i = 2
Select Case i
 Case Is>=0
   Print "Hello"
 Case Else
   Print "Goodbye"
End Select
> run "case_is.bas"
Error in line 4: IS is not declared
Add a space after the IS keyword and it works.
It's worse if you don't have OPTION EXPLICIT ON, because then this will unexpectedly print "Goodbye" !!!
Edited 2022-11-21 05:35 by thwill
Posted: 09:48pm 20 Nov 2022
Try:-
Select Case i
Case >=0
No IS in PicoMite manual
> for i=-2 to 2:Select Case i :Case >=0:Print "Hello":Case Else:Print "Goodbye":End Select :next
Goodbye
Goodbye
Hello
Hello
Hello
Edit
Need new glasses, IS is there.
This is interesting, without Option Explicit IS becomes a variable ANDed with i.
> for i=-2 to 2:Select Case i :Case is>=0:Print "Hello":Case Else:Print "Goodbye":End Select :next
Goodbye
Goodbye
Goodbye
Hello
Goodbye
> ? is
0
Edited 2022-11-21 08:18 by phil99
Posted: 10:12pm 20 Nov 2022
IS is optional in most (all?) MMBasic versions.
Posted: 10:25pm 20 Nov 2022
Known issue - no fix
Posted: 11:27pm 20 Nov 2022
Thanks for the pointers folks, especially to the fact that the inclusion of the IS keyword is unnecessary.
