Local Time 01:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: key interrupts
Posted: 07:29pm 12 Nov 2022
Hi folks,
I don't suppose I've missed some trick on the CMM2 to get an interrupt for a special key (e.g. shift or ctrl) ? The best I can come up with is a fast tick interrupt combined with KEYDOWN(). ON KEY doesn't do the trick because that seems to be triggered only by characters being added to the serial buffer.
frnno967
Posted: 05:35am 01 Dec 2022
I am interested in the answer to this question too. For no practical reason other than learning more about how KEYDOWN and ON KEY work at a deeper level.
Jay Crutti: Ham Radio Operator, K5JCJ. Computer Enthusiast. Musician. Engineer.
Posted: 08:26am 01 Dec 2022
  Quote  The best I can come up with is a fast tick interrupt combined with KEYDOWN(). ON KEY doesn't do the trick because that seems to be triggered only by characters being added to the serial buffer.
Correct. The modifier keys don't have an ascii character either real or pretend (function keys) so there is no other way of doing it than to poll
Posted: 04:03pm 01 Dec 2022
Thanks Peter. So far I've found the method that I've described to be adequate for my controller library use case.
