Local Time 07:17 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CO2 sensing
karlelch
Posted: 03:23pm 10 Nov 2022
Another German video ;-)
https://youtu.be/FfbP-4b5n9o
karlelch
Posted: 11:53am 11 Nov 2022
Here is the code to read out the CO2 sensor, if someone is interested.
The sensor is the SCD41, available as breakout from Pimoroni
Const I2C_ADDR = 98
Print "Initialize I2C ..."
SetPin GP0, GP1, I2C
I2C Open 100, 500
Print "Initialize sensor and start measuring ..."
I2C Write I2C_ADDR, 0, 2, &H36, &H46 : Pause 50
I2C Write I2C_ADDR, 0, 2, &H21, &HB1 : Pause 2
Function isDataAvailable()
 Local Integer buf(2) = (0,0,0)
 I2C Write I2C_ADDR, 0, 2, &HE4, &HB8 : Pause 2
 I2C Read I2C_ADDR, 0, 3, buf()
 isDataAvailable = ((buf(0) << 8) Or buf(1) And &HFFF) > 0
End Function
Sub getData CO2, Tmp, Hum
 Local Integer val, buf(8) = (0,0,0,0,0,0,0,0,0)
 I2C Write I2C_ADDR, 0, 2, &HEC, &H05 : Pause 1
 I2C Read I2C_ADDR, 0, 9, buf()
 CO2 = (buf(0) << 8) Or buf(1)
 val = (buf(3) << 8) Or buf(4)
 Tmp = (((21875 *val) >> 13) -45000) /1000
 val = (buf(6) << 8) Or buf(7)
 Hum = ((12500 *val) >> 13) /1000
End Sub
Dim integer i
Dim float CO2, T, H
For i=1 To 10
 Print "Waiting for data ..."
 Do : Pause 100 : Loop Until isDataAvailable()
 getData CO2, T, H
 Print "CO2 = " +Str$(CO2,5,0) +" ppm"
 Print "  T = " +Str$(T,-3,1) +Chr$(186) +"C"
 Print "  H = " +Str$(H,5,0) +"%"
 Pause 1000
Next i
Print "Stop measuring ..."
I2C Write I2C_ADDR, 0, 2, &H3F, &H86 : Pause 600
