Local Time 07:17 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite connects then disconnects in a loop
stanleyella
Posted: 08:05pm 09 Nov 2022
My picomite connected usb to win and then disconnected in a loop.
I disconnected all wiring and re flashed mmbasic but still the same.
I used https://geoffg.net/Downloads/picomite/Clear_Flash.uf2 then re flashed mmbasic
and now all is fine, just had to rewire and configure lcd panel.
What causes this?
Posted: 08:59pm 09 Nov 2022
That sort of thing is often related to the USB cable or connectors.
Running from an unpowered USB hub may do it too.
Check the 5V and 3V3 voltages.
stanleyella
Posted: 09:37pm 09 Nov 2022
  phil99 said  That sort of thing is often related to the USB cable or connectors.
I checked the wiring and it was ok.
Just a usb lead to picomite and I tried a few to just picomite, reflashed mmbasic but same connecting and disconnecting repeatedly. The reset code then reflash mmb and it all works fine.
There was nothing else I could think to do. Anyone had this problem?
Posted: 05:12am 10 Nov 2022
Did you reflash the same version of MMBASIC that was in it before the problem, or a different one?
Just curious...
Posted: 07:45am 10 Nov 2022
It's likely to do with saved OPTIONs across reflashes.
Could also be iffy power.
Don't dwell on it, just use clear and move on.
stanleyella
Posted: 04:15pm 10 Nov 2022
  Grogster said  Did you reflash the same version of MMBASIC that was in it before the problem, or a different one?
Just curious...
The same non vga picomite V5.07.04.uf2.
After using the "Reset.uf2" then above firmware and all is fine.
Has this connecting then disconnecting repeating on win 10 anyone else have happen to them?
karlelch
Posted: 05:55pm 10 Nov 2022
  Quote  Has this connecting then disconnecting repeating on win 10 anyone else have happen to them?
I had this problem when connecting the pico via a USB hub. Windows 11, though. Same USB cable connected to a USB port in the PC directly worked. For all other things, the USB hub works just fine. Puzzling ...
stanleyella
Posted: 07:24pm 10 Nov 2022
I can only think it was a lcd wiring problem and some how it messed up something,
lots of wires for lcd, touch and sd card.
It all works ok now but was a problem with no way out other than flash reset then flash firmware. odd. Mmedit crashed but ok with this picomite now.
