Forum Index : Microcontroller and PC projects : CMM2: World and State Capitals quizzes
| bar1010 Senior Member Joined: 10/08/2020 Location: United StatesPosts: 197 |
World and State Capitals quizzes for Color Maximite 2 There are three links below to download the three files. Had to split into three parts to avoid the 25MB upload limit on github. You can use 7-Zip Extract Here on the first of the three files. https://github.com/bar1010/Color-Maximite-2/blob/master/Quizzes.7z.001 https://github.com/bar1010/Color-Maximite-2/blob/master/Quizzes.7z.002 https://github.com/bar1010/Color-Maximite-2/blob/master/Quizzes.7z.003 |
| CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171 |
Listenbourg is missing |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1556 |
what about Tomainia? @bar1010 Sadly did'nt run on MMBasic 4 Windows, but maybee can be converted to the Pico by shrinking the Images and save as JPG. btw. wouldn't it be better to simple encrypt (ROT13) the data to keep players from cheating? Print ROT13$("Guvf vf n fghcvq fnzcyr grkg jvgu ab zrnavat 123!") Function ROT13$(encode$) Local f%,fnd% Local abc$="ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz" Local nop$="NOPQRSTUVWXYZABCDEFGHIJKLMnopqrstuvwxyzabcdefghijklm" For f%= 1 To Len(encode$) fin$=Mid$(encode$,f%,1) fnd%=Instr(abc$,fin$) If fnd% Then ROT13$=ROT13$+Mid$(nop$,fnd%,1) Else ROT13$=ROT13$+fin$ End If Next f% End Function Edited 2022-11-04 05:23 by Martin H. 'no comment |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 904 |
And I'm sorry but Melbourne is the capital of Victoria. Try Sydney as the capital of NSW. (but great program once the bugs are squished). Or is that an example of how it responds to an incorrect answer? Cheers, Andrew (Melbourne, Victoria, Australia) Edited 2022-11-04 04:41 by Andrew_G |
My answers to the questions are not necessarily the correct ones. |
Bill, Understood, and appreciated. Andrew |
The only change I had to make was include the full path to the data folders. After that, it runs happily in MMB4W Jim VK7JH MMedit |
