Local Time 01:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : strange behavior with BLIT operations on SSD1306I2C32
ville56
Posted: 07:33pm 02 Nov 2022
Hi all,
just tried to shift around an image on a SSD1306I2C32 display via BLIT WRITE on a pico.
BLIT LOAD #1, "filename"
BLIT WRITE #1,1,1
works as expeced and the image is displayed properly.
Shifting the image down vertically by incrementing the y position in the BLIT WRITE works as expected.
BUT shifting the image horizontially, e.g. BLIT WRITE #1,2,1 gives a completely distorted image. Looks somehow like the image is starting always at or near x-pos 1 but having a scale-factor in the x direction as the x-value increases.
Is there something i'm doing wrong with the x/y coordinates?
Thanks for any advice and regards,
Gerald
73 de OE1HGA, Gerald
stanleyella
Posted: 10:54pm 03 Nov 2022
2 pixel scrolling
OPTION EXPLICIT
dim counter
cls
'landscape
line 0,0,20,8
line 20,8,32,16
line 32,16,42,4
line 42,4,48,30
line 48,30,68,31
line 68,31,80,24
line 80,24,92,26
line 92,26,120,31
line 120,31,144,8
line 144,8,176,0
line 176,0,198,12
line 198,12,240,12
line 240,12,280,24
line 280,24,316,12
line 316,12,319,0
do
 for counter = 1 to 100
   scroll_left
 next counter
   scroll_right
 next counter
loop
sub scroll_left
 blit read 1,0,0,2,32
 blit read 2,2,0,318,32
 blit write 2,0,0,318,32
 blit write 1,318,0,2,32
 blit close 2
 blit close 1
end sub
sub scroll_right
 blit read 1,318,0,2,32
 blit read 2,0,0,318,32
 blit write 2,2,0,318,32
 blit write 1,0,0,2,32
 blit close 2
 blit close 1
end sub
Posted: 11:54pm 03 Nov 2022
@ville56
Although I don't have a SSD1306I2C32 display, on other displays you get that effect when the area being BLITed goes over the screen boundary.
Make sure
x + w < MM.HRES
and
y + h < MM.VRES
in
BLIT READ #b, x, y, w, h
BLIT WRITE #b, x, y, w, h
ville56
Posted: 11:07am 10 Nov 2022
Thanks for the hints and sorry for the late reply.
But for horizontial BLIT operations, meaning when the image is moved horizontially, i cannot get it working. Its either the BASIC internal display driver or the display hardware itself. So i probably have to live with it ...
Gerald
