Local Time 07:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION RTC AUTO ENABLE
VK2AHB
Posted: 12:51am 20 Oct 2022
I find that by powering off that I sometimes lose this option. Other options remain, but this one will disappear. Is there a reason for this?
Paul VK2AHB
Posted: 07:06am 20 Oct 2022
  Quote  Is there a reason for this?
This happens if the firmware doesn't see the RTC during any reset and is intended functionality in this case.
Posted: 07:24am 20 Oct 2022
Perhaps adding this to your program might work.
Sub MM.Startup
 If Right$(Date$) = "2000" Then RTC GetTime
End Sub
VK2AHB
Posted: 11:29am 20 Oct 2022
That's exactly what I've done. I then prompt for date and time input to set it.
Still doesn't explain why the option disappears though.
Paul
Posted: 02:16pm 20 Oct 2022
Is your RTC module (or whatever) making good contact and have a good battery?
Edited 2022-10-21 00:16 by Mixtel90
