Forum Index : Microcontroller and PC projects : Background Music (a Kind of ASCII ART)
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1556 |
After a discussion with Volhout how to Tokenise Music,here is my proposal. I tried out MidiNote and store as Ascii as the Note C2 starts at 36 and B7 is 107 this range should cover almost all possibilities We are able to store a complete Voice of a Melody in one String where Every Note uses just one Byte.. As 36 is the First Character that we use, we dont get in trouble with the " Char (34) the Player is "Tick" driven so it runs independend in Background and you can insert your Main Program in Frontground. This excample is just 2 Voice polyphone but 4 Voce will be possible 'Test ASCII Coded Background Music (with reference to MIDI note numbers) 'limitation to 255 Notes song length,since the max Stringlenght is 255 ' Exeptions: Space pauses the Note, # ends the song Dim FRQ%(128) Dim notes%(4,255) mt%=1:CNT%=1 Dim ADSR%(10)=(25,25,25,24,22,20,18,13,7,3,0) Dim ADSR2%(10)=(2,8,12,17,22,20,15,10,5,2,0) For f%=36 To 107:Read FRQ%(f%):Next :FRQ%(32)=1 'Sample Music just for this Test AA$="<>@ C C EC @ < > @ @ > < > <>@ C C EC @ < > @ @ > > < " AA$=AA$+"A A E E E C C @ > <>@ C C EC @ < >@ @ > > < #" AB$=" $0$0$0$0$0$0$0$0$0$0$0$0+7+7+7$0$0$0$0$0$0$0$0$0$0$0$0$" AB$=AB$+" $0$0$0$0$0$0$0$0$0+7+7$ #" cnt%=Len(AA$):Spos%=1 SetTick 20, music,4 MODE 2 Do Colour RGB(255,mt%*25,255) Print @(1,1)"'your Program here" Loop Sub music Local Fcent%,F1%,F2%,FL%,FR% If mt%=1 Then nt%=Asc(Mid$(AA$,CNT%,1)) If nt%=35 Then CNT%=1:nt%=Asc(Mid$(AA$,CNT%,1)) Freq1%=FRQ%(nt%) Freq2%=FRQ%(Asc(Mid$(AB$,CNT%,1))) Inc cnt% EndIf 'Pseudo Chorus Fcent%=Int(Freq1%/100) FL%=Freq1% - Fcent% FR%=Freq1% + Fcent% EndIf If Freq1%>1 Then Play sound 1,"L","q",FL%,adsr%(mt%):Play sound 3,"R","q",FR%,a dsr%(mt%) If Freq2%>1 Then Play sound 2,"B","w",Freq2%,adsr2%(mt%) Inc mt%:If mt%>10 Then mt%=1 End Sub 'Note to Frequency, starting with C2 (Midi 36) up to B7 (Midi 107) Data 65,69,73,78,82,87,93,98,104,110,117,123 Data 131,139,147,156,165,175,185,196,208,220,233,247 Data 262,277,294,311,330,349,370,392,415,440,466,494 Data 523,554,587,622,659,698,740,784,831,880,932,988,1047 Data 1109,1175,1245,1319,1397,1480,1568,1661,1760,1865,1976 Data 2093,2217,2349,2489,2637,2794,2960,3136,3322,3520,3729,3951 Cheers Martin Edited 2022-10-17 21:01 by Martin H. 'no comment |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
This is really impressive and a great idea for small games! Never thought it would be possible -Daniel |
| stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807 |
I will try with NON vga mmbasic... It will take a while to understand the code, (a few comments helps )I can not be bothered looking for a piezo speaker so I will use a powered one. is Inc cnt% same as cnt%=cnt%+1 or cnt%++ ? SetTick 20, music,4 ? Set up interrupt in NON vga mmb? Thanks for sharing. |
Hi Stanley, a few comments: Dim FRQ%(128) there the Frequency Values from the Data are stored, Dim notes%(4,255) Dim ADSR%(10)=(25,25,25,24,22,20,18,13,7,3,0) Dim ADSR2%(10)=(2,8,12,17,22,20,15,10,5,2,0) The ADSR volume curve for the "Instruments" the Sub is called 10 times per Note to process the ADSR volume curve, Therefor mt% is counting, if it reaches 11 it is set to 1 and a new tone is read. the Pseudo Chorus part detunes the lead voyce 1% up and down and uses 2 Oszilators to create a kind of chorus / flanging effect Sub music Local Fcent%,F1%,F2%,FL%,FR% If mt%=1 Then nt%=Asc(Mid$(AA$,CNT%,1)) If nt%=35 Then CNT%=1:nt%=Asc(Mid$(AA$,CNT%,1)) Freq1%=FRQ%(nt%) Freq2%=FRQ%(Asc(Mid$(AB$,CNT%,1))) Inc cnt% EndIf 'Pseudo Chorus Fcent%=Int(Freq1%/100) FL%=Freq1% - Fcent% FR%=Freq1% + Fcent% EndIf If Freq1%>1 Then Play sound 1,"L","q",FL%,adsr%(mt%):Play sound 3,"R","q",FR%,a dsr%(mt%) If Freq2%>1 Then Play sound 2,"B","w",Freq2%,adsr2%(mt%) Inc mt%:If mt%>10 Then mt%=1 End Sub Edited 2022-10-18 01:17 by Martin H. 'no comment |
Thanks. I got the vga mmb guide but not used vga mmb yet. ok my loss but the non vga is more my interest BUT the 2 could overlap ie vga 320x240 to lcd 320x240. vga version will be faster but I am liking lcd support so there will be speed differences but still my preference. vga uses second processor, so will be faster for graphics but lcd can be fast. it is the touch features I am interested in because they are well implemented, for a resistive display very good. It will never be as good as vga for games but some doable. |
edited the Comment while you answert, plz re-read the last Comment ![]() Edited 2022-10-18 01:29 by Martin H. 'no comment |
A few years ago, I wrote programs for the CMM2 to play QuickBasic sounds and Nocia phone sounds. Both programs should run on the pico. Edit: The pico doesn't seem to trigger an interrupt at the end of a TONE, only at the end of playing a WAV file. This means the program can be used to convert to another format but not play in the background on a pico. You can either use them to play the source as is or convert sound tracks to the format use in other program. The QB sound program ' playQB by TassyJim August 2020 ' To PLAY Quick Basic style sound strings. ' you can either use the function in your program directly or, ' more likely, use it to convert QBasic sound strings to DATA listings ' and use PLAY TONE in your progams ' OPTION EXPLICIT DIM playdone, p DIM dl$(150) ' array to store the converted data lines dl$(0) = "ToneData:" ' label for DATA p = 1 dl$(p) = " DATA " ' samples taken from QBasic games PLAYQB "MBT120L64O4cP32dP32eP32fP32gP32fP32eP32dP32c"'"T180 o2 P2 P8 L8 GGG L2 E-"+"P24 P8 L8 FFF L2 D" melodyEnd PAUSE 500 PLAYQB "MBMST220L64O1B"'"T120MLO2L1Eee" melodyEnd PAUSE 500 PLAYQB "MBMST220L64O6B"'"t120o1l16b9n0baan0bn0bn0baaan0b9n0baan0b" melodyEnd PAUSE 500 PLAYQB "o2l16e-9n0e-d-d-n0e-n0e-n0e-d-d-d-n0e-9n0e-d-d-n0e-" melodyEnd PAUSE 500 PLAYQB "o2l16g-9n0g-een0g-n0g-n0g-eeen0g-9n0g-een0g-" melodyEnd PAUSE 500 PLAYQB "o2l16b9n0baan0g-n0g-n0g-eeen0o1b9n0baan0b" melodyEnd '"MBT120L64O4cP32dP32eP32fP32gP32fP32eP32dP32c" "MBMST220L64O1B" "MBMST220L64O1B" "MBMST220L64O6B" printOutput END SUB playQB notation$ ' play a quickbasic string LOCAL ch$, item$, shift$= " " LOCAL AS INTEGER nNum, tempo, quarter, value, n LOCAL AS FLOAT pl, pauseTime, dur, ext, nTone LOCAL octave = 2 notation$ = notation$ + " " tempo = 120 quarter = 500 ' length of quarter note in mS dur = quarter pl = 7/8 ' normal note length playdone = 1 FOR n = 1 TO LEN(notation$) 'print item$; ch$ = MID$(notation$,n,1) SELECT CASE ch$ CASE "0","1","2","3","4","5","6","7","8","9" value = value * 10 + VAL(ch$) CASE ">" IF octave < 6 THEN octave = octave + 1 CASE "<" IF octave > 0 THEN octave = octave - 1 CASE "#","+" shift$ = "#" CASE "-" shift$ = "-" CASE "." IF ext = 0 THEN ext = dur/2 ELSE ext = dur*3/4 ENDIF CASE "X" ' ignore CASE ELSE ' print "Value = ";value 'DEBUG SELECT CASE item$ CASE "A","B","C","D","E","F","G" nNum = Note2nNum(item$+shift$, octave+2) nTone = nNum2Tone(nNum) DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE nTone, nTone, (dur + ext) * pl, playint dl$(p)=dl$(p)+STR$(nTone,4,1)+","+STR$((dur + ext) * pl,5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF IF pl < 1 THEN DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE 0, 0, (dur + ext) * (1 - pl), playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$((dur + ext) * (1 - pl),5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF ENDIF ext = 0 item$ = UCASE$(ch$) value = 0 CASE "T" tempo = value quarter = 60000 / tempo item$ = UCASE$(ch$) value = 0 ' print "quarter = ";quarter 'DEBUG CASE "L" dur = quarter * 4 / value item$ = UCASE$(ch$) value = 0 ' print "duration = ";duration 'DEBUG CASE "O" octave = value item$ = UCASE$(ch$) value = 0 CASE "P" pauseTime = quarter * 4 / value DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE 0, 0, pausetime, playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$(pausetime,5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF item$ = UCASE$(ch$) value = 0 CASE "T" tempo = value quarter = 60000/tempo item$ = UCASE$(ch$) value = 0 CASE "M" IF UCASE$(ch$) = "N" THEN pl = 7/8 IF UCASE$(ch$) = "L" THEN pl = 1 IF UCASE$(ch$) = "S" THEN pl = 3/4 item$ = " " value = 0 ' if ucase$(ch$) = "F" then ' foreground ' if ucase$(ch$) = "B" then ' background CASE "N" IF value = 0 THEN DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE 0, 0, (dur + ext) , playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$((dur + ext),5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF ELSE nTone = nNum2Tone(value+24) DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE nTone, nTone, (dur + ext) * pl, playint dl$(p)=dl$(p)+STR$(nTone,4,1)+","+STR$((dur + ext) * pl,5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF IF pl < 1 THEN DO : LOOP UNTIL playdone <> 0 : playdone=0 PLAY TONE 0, 0, (dur + ext) * (1 - pl), playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$((dur + ext) * (1 - pl),5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF ENDIF ext = 0 ENDIF item$ = UCASE$(ch$) value = 0 CASE ELSE item$ = UCASE$(ch$) value = 0 END SELECT shift$ = " " END SELECT NEXT n DO : LOOP UNTIL playdone <> 0 : playdone=0 END SUB SUB playint 'end of tone interrupt playdone=1 END SUB SUB melodyEnd dl$(p) = dl$(p)+" 0, 0" p = p+1 dl$(p) = " " p = p+1 dl$(p) = " DATA " END SUB FUNCTION Note2nNum(Note$, octave AS INTEGER) AS INTEGER ' given music note and octave, return piano key number LOCAL allNotes$ = "C C#D D#E F F#G G#A A#B " LOCAL altNotes$ = "C D-D E-E F G-G A-A B-B " LOCAL flat IF INSTR(Note$,"-") > 0 THEN flat = 1 Note$ = MID$(Note$,1,1) ENDIF IF LEN(Note$) < 2 THEN Note$ = Note$+" " IF Note$ = "E#" THEN Note$ = "F " ' correct for 2 undefined sharps IF Note$ = "B#" THEN Note$ = "C " : octave = octave + 1 IF Note$ = "F-" THEN Note$ = "E " ' correct for 2 undefined flats IF Note$ = "C-" THEN Note$ = "B " : octave = octave - 1 IF INSTR(Note$,"-")>0 THEN Note2nNum = INSTR(altNotes$,Note$)/2 +octave*12 - 9 - flat ELSE Note2nNum = INSTR(allNotes$,Note$)/2 +octave*12 - 9 - flat ENDIF IF Note2nNum < 1 THEN Note2nNum = Note2nNum + 1 ' correct for negative numbers END FUNCTION FUNCTION nNum2Tone(noteN AS INTEGER) AS FLOAT ' given piano key number return note frequency nNum2Tone = 440 * 2^((noteN-49)/12) END FUNCTION FUNCTION nNum2Octave(noteN AS INTEGER) AS INTEGER ' given piano key number, return octave number ' if noteN <98 and noteN > 88 then noteN = noteN - 97 IF noteN > 87 THEN : nNum2Octave = 8 ELSEIF noteN > 75 THEN : nNum2Octave = 7 ELSEIF noteN > 63 THEN : nNum2Octave = 6 ELSEIF noteN > 51 THEN : nNum2Octave = 5 ELSEIF noteN > 39 THEN : nNum2Octave = 4 ELSEIF noteN > 27 THEN : nNum2Octave = 3 ELSEIF noteN > 15 THEN : nNum2Octave = 2 ELSEIF noteN > 3 THEN : nNum2Octave = 1 ELSE : nNum2Octave = 0 ENDIF END FUNCTION FUNCTION nNum2Note(noteN AS INTEGER) AS STRING ' given piano key number, return music note LOCAL allnotes$ = "G#A A#B C C#D D#E F F#G G#A " noteN = noteN + 12 IF noteN > 0 THEN nNum2Note = MID$(allnotes$,(noteN MOD 12) * 2 +1,2) ENDIF END FUNCTION SUB printOutput LOCAL p DO PRINT dl$(p) p = p + 1 LOOP UNTIL dl$(p) = "" END SUB The Nocia phone program. ' playNokia by TassyJim August 2020 ' play Nokia ringtones and convert to tone - duration pairs of DATA ' ' OPTION EXPLICIT DIM playdone, n DIM source$(11) ' array for the source tune DIM dl$(150) ' array to store the converted data lines DIM newName$ DIM d=4, o=5, b=120, pl = 7/8 ' normal note length 'input "Default length, octave, beats (4,5,120): ";d,o,b RESTORE testtune 'jinglebells ' read the source data into a string array ' output is DATA statements in array dl$() DO n = n + 1 READ source$(n) IF source$(n) = "" THEN EXIT DO LOOP playNokia printOutput END SUB playNokia ' play a nokia string ' and convert it to tone, duration DATA pairs LOCAL ch$, item$, shift$= " " LOCAL AS INTEGER nNum, tempo, quarter, value, n, k, p, lastone LOCAL AS FLOAT dur, ext, nTone LOCAL octave k = INSTR(source$(1),":") ' look for file header IF k>0 THEN ' get name and settings newName$ = LEFT$(source$(1),k-1) k = INSTR(source$(1),"d=") ' default note duration IF k THEN n = INSTR(k,source$(1),",")-k-2 d = VAL(MID$(source$(1), k+2,n)) ENDIF k = INSTR(source$(1),"o=") ' default octave IF k THEN n = INSTR(k,source$(1),",")-k-2 o = VAL(MID$(source$(1), k+2,n)) ENDIF k = INSTR(source$(1),"b=") ' default tempo IF k THEN n = INSTR(k,source$(1),":")-k-2 b = VAL(MID$(source$(1), k+2,n)) ENDIF source$(1) = MID$(source$(1),k+n+3) ' strip off header ' print newName$, d, o, b 'DEBUG ' print source$(1) 'DEBUG ELSE newName$ = "Test" ENDIF dl$(0) = newName$+":" ' label for DATA p = 1 dl$(p) = " DATA " tempo = b octave = o quarter = 60000 / tempo ' length of quarter note in mS dur = quarter * 4 / d 'pl = 7/8 ' normal note length playdone = 1 FOR k = 1 TO 11 IF LEN(source$(k)) = 0 THEN source$(k) = "," 'add final comma lastone = 1 'and set flag ENDIF FOR n = 1 TO LEN(source$(k)) ch$ = UCASE$(MID$(source$(k),n,1)) SELECT CASE ch$ CASE "0","1","2","3","4","5","6","7","8","9" value = value * 10 + VAL(ch$) CASE "A","B","C","D","E","F","G","P" item$ = ch$ IF value = 0 THEN dur = quarter * 4 / d ELSE dur = quarter * 4 / value ENDIF value = 0 CASE "#","+" shift$ = "#" CASE "-" shift$ = "-" CASE "." IF ext = 0 THEN ext = dur/2 ELSE ext = dur*3/4 ENDIF CASE " " ' skip CASE "," IF value = 0 THEN octave = o ELSE octave = value ENDIF 'playdone=0 IF item$ = "P" THEN ' rest DO : LOOP UNTIL playdone<> 0 : playdone=0 PLAY TONE 0, 0, (dur + ext), playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$((dur + ext),5,1) IF LEN(dl$(p)) < 65 THEN ' check for new line required dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF ELSE nNum = Note2nNum(item$+shift$, octave-1) nTone = nNum2Tone(nNum) DO : LOOP UNTIL playdone<> 0 : playdone=0 PLAY TONE nTone, nTone, (dur + ext) * pl, playint dl$(p)=dl$(p)+STR$(nTone,4,1)+","+STR$((dur + ext)* pl,5,1) IF LEN(dl$(p)) < 65 THEN dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF IF pl < 1 THEN DO : LOOP UNTIL playdone<> 0 : playdone=0' wait for current tone to finish PLAY TONE 0, 0, (dur + ext) * (1 - pl), playint dl$(p)=dl$(p)+STR$(0,4,1)+","+STR$((dur + ext)* (1 - pl),5,1) IF LEN(dl$(p)) < 65 THEN dl$(p)=dl$(p)+"," ELSE p = p+1 dl$(p) = " DATA " ENDIF ENDIF ENDIF value = 0 shift$ = " " ext = 0 END SELECT NEXT n IF lastone = 1 THEN EXIT FOR ' all done! NEXT k dl$(p) = LEFT$(dl$(p),LEN(dl$(p))-1)+", 0,0" dl$(p+1) = "' End of "+newName$ dl$(p+2) = "" DO : LOOP UNTIL playdone<> 0 : playdone=0' wait for current tone to finish END SUB SUB printOutput LOCAL p DO PRINT dl$(p) p = p + 1 LOOP UNTIL dl$(p) = "" END SUB SUB playint 'end of tone interrupt playdone=1 END SUB SUB melodyEnd PRINT "DATA 0, 00" END SUB FUNCTION Note2nNum(Note$, octave AS INTEGER) AS INTEGER ' given music note and octave, return piano key number LOCAL allNotes$ = "C C#D D#E F F#G G#A A#B " LOCAL altNotes$ = "C D-D E-E F G-G A-A B-B " LOCAL flat IF INSTR(Note$,"-") > 0 THEN flat = 1 Note$ = MID$(Note$,1,1) ENDIF IF LEN(Note$) < 2 THEN Note$ = Note$+" " IF Note$ = "E#" THEN Note$ = "F " ' correct for 2 undefined sharps IF Note$ = "B#" THEN Note$ = "C " : octave = octave + 1 IF Note$ = "F-" THEN Note$ = "E " ' correct for 2 undefined flats IF Note$ = "C-" THEN Note$ = "B " : octave = octave - 1 IF INSTR(Note$,"-")>0 THEN Note2nNum = INSTR(altNotes$,Note$)/2 +octave*12 - 9 - flat ELSE Note2nNum = INSTR(allNotes$,Note$)/2 +octave*12 - 9 - flat ENDIF IF Note2nNum < 1 THEN Note2nNum = Note2nNum + 1 ' correct for negative numbers END FUNCTION FUNCTION nNum2Tone(noteN AS INTEGER) AS FLOAT ' given piano key number return note frequency nNum2Tone = 440 * 2^((noteN-49)/12) END FUNCTION FUNCTION nNum2Octave(noteN AS INTEGER) AS INTEGER ' given piano key number, return octave number ' if noteN <98 and noteN > 88 then noteN = noteN - 97 IF noteN > 87 THEN : nNum2Octave = 8 ELSEIF noteN > 75 THEN : nNum2Octave = 7 ELSEIF noteN > 63 THEN : nNum2Octave = 6 ELSEIF noteN > 51 THEN : nNum2Octave = 5 ELSEIF noteN > 39 THEN : nNum2Octave = 4 ELSEIF noteN > 27 THEN : nNum2Octave = 3 ELSEIF noteN > 15 THEN : nNum2Octave = 2 ELSEIF noteN > 3 THEN : nNum2Octave = 1 ELSE : nNum2Octave = 0 ENDIF END FUNCTION FUNCTION nNum2Note(noteN AS INTEGER) AS STRING ' given piano key number, return music note LOCAL allnotes$ = "G#A A#B C C#D D#E F F#G G#A " noteN = noteN + 12 IF noteN > 0 THEN nNum2Note = MID$(allnotes$,(noteN MOD 12) * 2 +1,2) ENDIF END FUNCTION JingleBells: 'd=4,o=5,b=125 DATA "JingleBells:d=4,o=5,b=125:8g,8e6,8d6,8c6,2g,8g,8e6,8d6,8c6,2a,8a,8f6,8e6" DATA "8d6,8b,8g,8b,8d6,8g.6,16g6,8f6,8d6,2e6,8g,8e6,8d6,8c6,2g,16f#,8g,8e6" DATA "8d6,8c6,2a,8a,8f6,8e6,8d6,8g6,16g6,16f#6,16g6,16f#6,16g6,16g#6,8a.6" DATA "16g6,8e6,8d6,c6,g6,8e6,8e6,8e.6,16d#6,8e6,8e6,8e.6,16d#6,8e6,8g6,8c.6" DATA "16d6,2e6,8f6,8f6,8f.6,16f6,8f6,8e6,8e6,16e6,16e6,8e6,8d6,8d6,8e6,2d6" DATA "" DATA "g,c7,g,e,g,c.7,8c7,c7,e7,d7,c7,b,c7,2d.7,g,c7,g,e,c,g.,8g,g,e7,d7,c7,b" DATA "a,2g,p,g,a.,8b,c7,a,2g,8e,e,g,a,c7,f7,e7,2d7" DATA "" testtune: DATA "g,g,a,f#.,8g,a,b,b,c6,b.,8a,g,a,g,f#,g.,8a,8b,8c6,d6,d6,d6,d.6,8c6,b,c6" DATA "c6,c6,c.6,8b,a,b,8c6,8b,8a,8g,b.,8c6,d6,8e6,8c6,b,a,g." DATA "" DATA "8c#,8d,e,c#,d,b4,c#,a4,b4,p,16c#6,16p,16d6,16p,8e6,8p,8c#6,8p,8d6,8p" DATA "8b,8p,8c#6,8p,8a,8p,b,p,a4,a4,b4,c#,a4,c#,b4,p,8a,8p,8a,8p,8b,8p,8c#6" DATA "8p,8a,8p,8c#6,8p,8b" DATA "" There are plenty of Nocia tunes out there on the 'net and plenty of QuickBasic programs have sound effects embedded in them. Jim Edited 2022-10-18 06:39 by TassyJim VK7JH MMedit |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6122 |
In Europe they where sold under the name Nokia. With K. PicomiteVGA PETSCII ROBOTS |
![]() 'no comment |
if you look at my sub , the Tone ends when mt%>10 That cause the sub to read the next Tone(s). so, with a little tinkering, it should be possible to use the QB program on the Pico as well. Next 2 Days not Time for Programming, but I will have a look 'no comment |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11889 |
This is a bug, it should - will fix UPDATE: fixed in RC8 Edited 2022-10-19 23:10 by matherp |
Hi Martin, I have profiled your code in the first post, and it is impressive sound with all the ADSR and chorus. But it consumes 51% CPU power at 252MHz. For reference, playing CD music (44.1kHz stereo) from SD card only consumes 27% CPU power at 252MHz. Of coarse that does not support in game sounds... Volhout Edited 2022-10-20 04:20 by Volhout PicomiteVGA PETSCII ROBOTS |
well ... Time for optimisation The cent calculation for the Pseudo Chorus is done every 20 mS (with every call of the Sub). This is not necessary If we move the Chorus calculation within the IF statement, then the Chorus will be calculated only every 10th call (every 200 mS) without loosing the ADSR and the "Chorus". This should reduse the CPU Consumption. but we lose our local variables Sub music 'Local Fcent%,F1%,F2%,FL%,FR% If mt%=1 Then nt%=Asc(Mid$(AA$,CNT%,1)) If nt%=35 Then CNT%=1:nt%=Asc(Mid$(AA$,CNT%,1)) Freq1%=FRQ%(nt%) Freq2%=FRQ%(Asc(Mid$(AB$,CNT%,1))) 'Pseudo Chorus Fcent%=Int(Freq1%/100) FL%=Freq1% - Fcent% FR%=Freq1% + Fcent% Inc cnt% EndIf If Freq1%>1 Then Play sound 1,"L","q",FL%,adsr%(mt%):Play sound 3,"R","q",FR%,a dsr%(mt%) If Freq2%>1 Then Play sound 2,"B","w",Freq2%,adsr2%(mt%) Inc mt%:If mt%>10 Then mt%=1 End Sub Edited 2022-10-20 04:30 by Martin H. 'no comment |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3382 |
By trial and error I have noticed local variables, especially large arrays, slow the Pico down a little more than global ones. Putting as much of the program as possible in the main loop gains a little more speed. |
CPU load is 48% now (from 51%). Apparently there is a lot of CPU in the play commands themselves. You can still shave 2% CPU power off, when you change the ADSR from 10 steps to 6 steps, without much loss of sound quality. SETTICK to 36ms. Manual mentions that some 25% is used simply by playing. Not sure if we can improve any further. Volhout Edited 2022-10-25 06:22 by Volhout PicomiteVGA PETSCII ROBOTS |
