Forum Index : Microcontroller and PC projects : Raspberry or Babana?
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
How about this Esp32 with wifi and bluetooth the same pinout and size as the raspberry pico? Could this be ported? or are all Esp32's useless? |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4380 |
It could - but remember Peter has previously posted just how much work a "port" (re-write of all hardware-related parts) is. (Months, or at least weeks, not days. Using C.) John Edited 2022-09-28 02:06 by JohnS |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
ESP32s are in no way useless. Annex Basic runs nicely on them. As far as porting goes (if I recall correctly), Peter said some years ago that the ESP32 was quite capable of running MMBasic, that he had ported the core functionality except for pin I/O (the hardest part of the job), and if someone wanted to undertake that I/O, he would provide the code he already had. And as of now you can run simulations using them: Annex ESP32 web simulation I'm not sure what great advantage there is to having the Pico pinout for the ESP32 (though I guess some of my PCBs could be used with them). ~ Edited 2022-09-28 02:55 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11890 |
Not quite, I said I would do the I/O but I needed someone to do the web I/F so, for example, you could edit from a browser. I had MMBasic up and running with SDcard and logging into wifi from what I remember. Seem to have lost both the code and IDE in a PC upgrade earlier this year though and Pico will be my last port as it gets boring after a time. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6122 |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 653 |
I can't wait to see what your next big project is going to be! But yes, I would also like to thank you for what you and Geoff have created here. You have truly inspired me in many ways - from reliving my childhood programming in BASIC, to demonstrating what these chips are capable of. This has obviously been a massive (heroic?) undertaking that most people would have given up on a long time ago. Thank you from the bottom of my heart. |
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
That's like hearing your favourite band announcing their last and final tour |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4398 |
Rumours of Peter's death seem greatly exaggerated, all he said was that he wasn't doing any more ports. He hasn't for example said that he is going to stop supporting his existing ports, join the Foreign Legion or give up electronics in favour of needlework .Which isn't to say I don't echo the thanks of the other posters. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Historically it's considered to be rather rude to make "Me too" posts, but sod it... Me too. Mick Zilog Inside! nascom.info for Nascom & Gemini |
