Local Time 08:18 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 vs. PicoMite 2 Mio For-Next-Benchmark
andreas
Posted: 08:47am 23 Sep 2022
2 Mio For..Next Loops
CMM2:
PicoMiteVGA:
The CMM2 (480MHz) is 8.3 times faster than the PicoMiteVGA (126MHz)
The CMM2 has an #include-statement which enables modular software.
-andreas
Martin H.
Posted: 09:37am 23 Sep 2022
Messung von 2000000 For-Next - Statents
Pro Sekunde:      268592
Gesamtlaufzeit:   7.446217
> option list
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 378000
OPTION SDCARD GP10, GP12, GP11, GP13
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
with OPTION CPUSPEED 378000
~ half as fast as cmm2
Print "Messung von 2000000 For-Next - Statents"
Print "----------------------------------------"
t%=Timer
For f%=1 To 2000000
Next f%
l= Timer-t%
Print "Pro Sekunde:     ";Int(2000000/(l/1000))
Print "Gesamtlaufzeit:  "l /1000
a littlie faster, if I put the Next statement in the same Line as the For Statement :
Pro Sekunde:      275513
Gesamtlaufzeit:   7.259177
but .. if I delete the Variable behind the NEXT Statement
Pro Sekunde:      589522
Gesamtlaufzeit:   3.392575
t%=Timer
For f%=1 To 2000000:Next
l= Timer-t%
the question remains, how meaningful such test results are
Mart!n
Edited 2022-09-23 19:59 by Martin H.
'no comment
Posted: 12:47pm 23 Sep 2022
As an experiment to see how fast a Pico can read a pin in a FOR - NEXT loop I wrote a program to read a DHT11 temp / humidity sensor and found you can fill an array at 15uS per sample.
CPUSPEED = 378000 kHz, a one digit pin number and all on one line. Every character slows it down.
Here is the relevant part.
'Data format - 80uS high start pulse, 50uS low + 25uS high = 0, 50uS low + 70uS high = 1
Dim integer n
' deliver 20 mS pulse to wake up DHT11
 SetPin 1,dout,oc
 Pin(1)=1
 Pulse 1,20
 Pause 19
 SetPin 1,off
 SetPin 1,din 'Get the samples
 For n=0 To 329:a(n)=Pin(1):Next
 SetPin 1, off  'Got the samples
'for max. speed the above 'for-next' must be on one line with fewest characters
Edited 2022-09-24 09:01 by phil99
andreas
Posted: 07:41pm 25 Sep 2022
  phil99 said  As an experiment to see how fast a Pico can read a pin in a FOR - NEXT loop I wrote a program to read a DHT11 temp / humidity sensor and found you can fill an array at 15uS per sample.
Dim integer n
 SetPin 1,dout,oc
 Pin(1)=1
 Pulse 1,20
 Pause 19
 SetPin 1,off
Very interesting! So one can sample more than 1/15uS = 66666 samples a seconds using for-next on a pico.
-andreas
Posted: 07:57pm 25 Sep 2022
And 32000000 times per seond using the PIO.
Posted: 11:36pm 25 Sep 2022
"And 32000000 times per second using the PIO."
Yes indeed, if you have A Need for Speed.
ADC and CSUB LOG also work well.
Update on the For - Next. The 15uS per sample was before I added
Dim Integer n
That reduced it to 12.4uS per sample = 80,645 samples / second.
I had assumed, wrongly, that the counter in a For - Next would automatically be an integer.
That enables it to catch the 25uS pulses at 252MHz most of the time.
Tinine
Posted: 04:06am 26 Sep 2022
-andreas
Because it runs from SD?
Craig
Tinine
Posted: 04:09am 26 Sep 2022
  phil99 said  "And 32000000 times per second using the PIO."
Dim Integer n
Doesn't a decrementing For-Next run even faster?
Craig
Tinine
Posted: 06:56am 26 Sep 2022
For decades, I have been using a high-end industrial controller (read:expensive) which consists of a real-time back-end and an extemely crude BASIC-like interpreter on the front-end.
This interpreter has one data-type which is float. A literal string can be produced using a 2-character mnemonic MG"Hello World" (MG = message).
I have been able to achieve all I need with this language and I never wondered about execution speed because it's never been a concern.
I spent yesterday going through their documentation and the same for other similar high-end products and heck, PMBasic totally blows them out of the water. Turns out that the product I was using ten years ago which I regarded as stupidly fast, has a command execution time of 400uS
Then I moved-on to a newer model that boasted "10 times faster"...40uS...What's that, a MMBasic PIC32MX170 @40MHz?
Their flagship is 11uS and that would cost me close to £4K
Another big-name alternative ($4.4K Used on eBay) cautions about the limitations of their 32bits and single precision. Also runs @ ~25,000 lines/sec.
MMBasic just totally freaking ROCKS!!!
Craig
Posted: 08:04am 26 Sep 2022
"Doesn't a decrementing For-Next run even faster?"
I must try it.
Now that you have jogged my decrepit memory I may have done that in the past.
Plasmamac
Posted: 09:11am 26 Sep 2022
@andreas where can i find the pcb from your Picomite?
Plasma
Martin H.
Posted: 12:45pm 26 Sep 2022
Craig
hmm no
t%=Timer
For f%=2000000 To 1 Step -1:Next
l= Timer-t%
Pro Sekunde:      583799
Gesamtlaufzeit:   3.425835
Mart!n
'no comment
Posted: 12:56pm 26 Sep 2022
"hmm no"
Got the same result. What little gain there might have been was offset by the extra characters STEP -1
andreas
Posted: 02:30pm 26 Sep 2022
  Tinine said
-andreas
Craig
Yes, the CMM2 has a SD-Card. But the picos can have a sd-card also. If one uses a pico as data logger, educational hardware, game machine, hobbyist thing - it makes sense to have a mass storage.
#include in MMBASIC is the same as a definition/implementation module in Modula-2 or a DLL in Windows or a word in FORTH. You need it if you want to write code only once for a certain task and create more and more complex software out of simple building blocks.
-andreas
andreas
Posted: 02:42pm 26 Sep 2022
  Plasmamac said  @andreas where can i find the pcb from your Picomite?
Hi Plasma, do you mean this one?
This is from Silicon Chip magazin July 22 VGA PicoMite ($5) or Kit ($35).
-andreas
andreas
Posted: 03:14pm 26 Sep 2022
Don't ask me what is going on here - this version does it in a second!
Can someone verify this? I'm curious where the mistake is - but this seems to be too fast, isn't it?
' speed.bas - Laufzeitmessung
CLS
CONST Maxloop = 2000000        ' Anzahl der Loops
DIM Laufzeit AS FLOAT = 0.0    ' in Sekunden
DIM a AS INTEGER = 0           ' Dummy
DIM T1 AS INTEGER = 0
DIM T2 AS INTEGER = 0          ' Timer in Millisekunden
PRINT
PRINT "Messung von ";Maxloop%;" For-Next - Statements"
PRINT "------------------------------------------"
PRINT
T1 = timer
for a = 1 to Maxloop:next
T2 = timer
Laufzeit = (T2 - T1)/1000.0
PRINT "Pro Sekunde:    ";INT(Maxloop/Laufzeit);" Iterationen"
PRINT "Gesamtlaufzeit: ";Laufzeit;" Sekunden"
save image "cmm2.bmp"
The CMM2 is not "tuned" it simply runs @ 480MHz.
-andreas
andreas
Posted: 06:15pm 26 Sep 2022
Using the same code on the PicoMiteVGA (simply by using the same sd-card) I get improved values:
By comparing the old benchmark code to the current code there is one major difference: In the new faster code I did declare the control variable as integer before use within the for..next construct.
Result: Declaring control variables before use results in huge speed-up!
Example:
CONST Maxloop = 10000000
DIM i AS INTEGER = 0        ' gives huge speed-up
FOR i = 1 to Maxloop
 'Do_something
NEXT                        ' do not write i after NEXT
It seem to be very important not to write down the control variable after the next-statement.
Writing: for i = 1 to Maxloop : next
is much faster than
writing: for i = 1 to Maxloop : next i
Doing real measurements on the cmm2 within the for..next loop:
' bench.bas - how fast can you measure
const maxmeasure = 500000 ' number of measurements
cls
dim mess(maxmeasure) as integer
dim i as integer = 0
setpin 33,din ' digital input on pin 33
print "Start... ";
t1 = timer
for i = 1 to maxmeasure: mess(i) = pin(33):next
diff=timer-t1
print diff;" ms for ";maxmeasure;" measurements"
print
print (maxmeasure/diff)*1000;" measurements per second"
print
memory
save image "camac.bmp"
-andreas
Edited 2022-09-27 06:46 by andreas
