Local Time 08:37 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoVGA VGA output with USB serial control?
shellberight
Posted: 05:25am 22 Sep 2022
I haven't gotten a spare VGA monitor yet, so I'm programming the PicoVGA with the USB connection.  Is it possible to continue to program from this connection with a VGA monitor attached directly to the PicoVGA as well?  It would allow me to continue to program from my desktop computer while displaying the graphics commands on the VGA monitor.
Is there some special commands I need to invoke to do this or just hook up a VGA monitor?
Amnesie
Posted: 05:52am 22 Sep 2022
You can connect via terminal of choice via computer & see the output on the VGA Monitor, this works.
shellberight
Posted: 08:25pm 23 Sep 2022
In addition is there a way to keep MODE 1 applied to the USB connection while the VGA connection runs in MODE 2?
Posted: 09:08pm 23 Sep 2022
Not that I know of. Sceen resolution for both is the same(lines and chars per line)
Only differences are
- serial terminal is text only
- serial terminal has colorcoding, vga only in mode 2
I made my life easier by programming
option f5 "mode 1:edit"+chr$(13)
Edited 2022-09-24 07:15 by Volhout
Martin H.
Posted: 07:52am 24 Sep 2022
in PicoMite(VGA) Version V5.07.05 there is an optional Edit parameter so if you type
EDIT 1
your editor (and Termina Window) will change to mode 1 for Editing.
  Mart!n
'no comment
