Local Time 02:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Memory Map
Nimue
Posted: 07:14pm 19 Sep 2022
Hi all
Is there a PicoMite (non VGA if that makes a difference) memory map available?
I am attempting to teach all things "memory" and have resorted to the ZX Spectrum and Vic20 / Electron memory maps as they are relatively easy to explain / understand.   Using such I can add things to memory and retrieve them with PEEK / POKE or equivalent.
I have checked the manual ;-)
N
Posted: 07:21pm 19 Sep 2022
If you just want an area to peek and poke in then you can use PEEK(VARADDR var) to find the start address of a string then POKE and PEEK using that address with an offset to select the address. This has the advantage that, if you keep the POKEable area less than 250 bytes or so it's completely safe. ADDR+0 is the string length (default is 256 bytes IIRC). ADDR+1 is the first byte of the string.
Note that PRINTing the string may not be reliable as not all characters from &H0 to &HFF are printable, although you can PEEK and POKE them.
Edited 2022-09-20 05:25 by Mixtel90
Nimue
Posted: 07:34pm 19 Sep 2022
  Mixtel90 said  If you just want an area to peek and poke in then you can use PEEK(VARADDR var) to find the start address of a string then POKE and PEEK using that address with an offset to select the address. This has the advantage that, if you keep the POKEable area less than 250 bytes or so it's completely safe. ADDR+0 is the string length (default is 256 bytes IIRC). ADDR+1 is the first byte of the string.
Perfect - works a treat.  Thank you.
Is there a "map" though somewhere -- as the above require me to define a variable first.  What if I just want to write/read memory at the get go?
For example, in recent threads, getting the internal temperature is mentioned.  Presumably somewhere in memory this exists in a raw version and the MMBasic OS just interprets / calculates something from this?   So, can I pull the raw value from the Pico -- to do so needs a memory map?  (Happy to be told I'm wrong about all this ;-) )
N
Posted: 09:00pm 19 Sep 2022
This is the closest I know of.
The PicoMite isn't what you might expect. The program is in flash, the variables are in RAM. Consequently you don't have large chunks of contiguous memory area to play in.
Edited 2022-09-20 07:04 by Mixtel90
stanleyella
Posted: 10:13pm 19 Sep 2022
  Mixtel90 said  This is the closest I know of.
I have not needed to use peek/poke but it is in the manual. Not much about bit usage.
Is it handled fast in mmbasic before I try? Using integers for bit values I can not access apart from masking using and.
If one dim'd an array is there no pointer to it that could be used as a start of an "address" in ram?
A blit buffer seems constant so could a blit buffer be used as ram in that it is writable and readable? Just a beginner.
Posted: 10:48pm 19 Sep 2022
  Nimue said  What if I just want to write/read memory at the get go?
With care, you can.
  Nimue said  For example, in recent threads, getting the internal temperature is mentioned.  Presumably somewhere in memory this exists in a raw version and the MMBasic OS just interprets / calculates something from this?   So, can I pull the raw value from the Pico -- to do so needs a memory map?
Refer to the MMBasic pico sources / pico datasheet e.g. for the addresses of hardware / examples of accessing hardware (I/O registers etc).
Expect some grief (CPU resets etc).
Edited 2022-09-20 08:49 by JohnS
Posted: 11:54pm 19 Sep 2022
@stanleyella
Mixtel90 explains it clearly in post 2 of this thread.
S$ = "The quick brown fox jumps over the lazy God."
> ? PEEK(VARADDR S$)
537024256
> ? PEEK(byte 537024256+0)
44
> For n=1 to 44 : Print chr$(PEEK(byte 537024256+n)); : next
> ? PEEK(byte 537024256+41)
71
> ? PEEK(byte 537024256+43)
100
>  POKE byte 537024256+43,71
>  POKE byte 537024256+41,100
> For n=1 to 44 : ? chr$(PEEK(byte 537024256+n)); : next
The quick brown fox jumps over the lazy doG.
> ? s$
Byte 0 of a string is its length. In normal use it is hidden.
Edited 2022-09-20 11:15 by phil99
