Local Time 02:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC settime
VK2AHB
Posted: 08:15am 08 Sep 2022
Does this set the 2040 chip clock, the external 3231 or both? I can't get mine to keep the time if I disconnect the power. Time resets to 00:00:00.
Paul VK2AHB
Posted: 08:47am 08 Sep 2022
RTC SetTime sets the external RTC.
RTC GetTime sets the MMBasic clock to the RTC time.
Posted: 10:15am 08 Sep 2022
The MMBasic clock will always reset to 00:00:00 as it has no battery. The RTC has battery backup so it keeps running. :)
If you have a RTC connected, you can use OPTION RTC AUTO ENABLE to automatically set the MMBasic clock from the RTC on boot and every hour. You can turn this off with OPTION RTC AUTO DISABLE.
Posted: 10:29am 08 Sep 2022
note that for the OPTION RTC AUTO ENABLE to work you do need to define the I2C bus where the DS3231 connects. This is also set with an OPTION statement.
So for RTC SETTIME and RTC GETTIME to work you need to set following OPTIONS:
OPTION SYSTEM I2C sda_pin,scl_pin  (i.e. OPTION SYSTEM I2C GP14,GP15)
Then reboot the system
Then set the RTC to the correct time
RTC SETTIME 2022,09,08,12,23,10
You can reboot the system, or do a RTC GETTIME
And you will have the correct time available in variables
TIME$
DATE$
P.S. this is also explained on page 32 of the user manual
Edited 2022-09-08 20:31 by Volhout
VK2AHB
Posted: 12:35pm 08 Sep 2022
Thanks for that, RTC AUTO ENABLE did the trick.
Paul
