Local Time 02:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 32bit to 64bit
Tinine
Posted: 05:49pm 07 Sep 2022
I have a 32bit counter that I will assign to MMBasic's 64bit integer.
When I hit rollover, I want the 64bit to keep counting in whatever direction.
I can think of ways to do this but I suspect that whatever I come up with will be clunky
What's the niftiest way of doing this?
Craig
Posted: 06:08pm 07 Sep 2022
Does this do what you want ?
if new32<the64 mod &HFFFFFFFF then 'counter has rolled over
   inc the64, &H100000000+new64
else 'just replace the bottom 32 bits
   the64 = (the64 and &HFFFFFFFF00000000) + new32
endif
Tinine
Posted: 07:28pm 07 Sep 2022
Ah-ha, I was actually on the right track but there's a bit there that you showed me in the past.
Will have a play
Many, many thanks, Pete
Posted: 07:34pm 07 Sep 2022
http://www.fruitoftheshed.com/MMBasic.Sign-Extend-an-Integer.ashx
Tinine
Posted: 08:01pm 07 Sep 2022
Honestly....as I was typing the OP, I was thinking...it's gonna be Pete or Cap'n
Just fell out of the attic, retrieving a bunch of 3.5" floppies...don't ask
Craig
Tinine
Posted: 05:34am 08 Sep 2022
  CaptainBoing said  http://www.fruitoftheshed.com/MMBasic.Sign-Extend-an-Integer.ashx
Morning, Cap'n
OK, just got to my desk with first coffee of the morning.
At first glance, I will need to expand upon this, right?
I mean; if my counter is running in the positive direction, bit31 is going to be flipping hi/lo multiple times but I want my 64bit integer to keep counting positive.
Naturally, it also needs to work for the other direction.
Craig
Posted: 06:45am 08 Sep 2022
Sorry Craig, so the 64 bit counter needs to go up regardless of the direction of the 32 bit?
e.g.
counter32 increments 10 steps: counter64 bit increments 10 steps,
counter32 decrements 10 steps: counter64 bit increments 10 steps ?
in which case ignore my post, I thought (from my brief scan) that you wanted to convert a signed 32 bit to a signed 64bit.
that function I posted just extends all zeros or all ones from a certain point to bit 63
I blame old age and drink...
Edited 2022-09-08 16:47 by CaptainBoing
Tinine
Posted: 07:07am 08 Sep 2022
  CaptainBoing said  Sorry Craig, so the 64 bit counter needs to go up regardless of the direction of the 32 bit?
e.g.
Yeah, for example, there are devices with 8 or 16 bit physical counters but from a coding standpoint we have a 32 bit counter. I can see how to do this but we share an obsession for efficiency   and so I want the leanest solution.
I'll post what I come-up with, based on the sort of thing that Pete posted and see if you guys can trim it
Craig
Posted: 07:30am 08 Sep 2022
  Tinine said   we share an obsession for efficiency   and so I want the leanest solution.
totally get that. years of 80s (and 90s a bit) assembler programming taught me to keep my room tidy
vegipete
Posted: 03:53pm 08 Sep 2022
Are you just hosting a 32 bit up-down counter in a 64 bit variable? If you are not doing any signed math, you don't need to do anything - it just works.
Tinine
Posted: 05:08pm 08 Sep 2022
  vegipete said  Are you just hosting a 32 bit up-down counter in a 64 bit variable? If you are not doing any signed math, you don't need to do anything - it just works.
This is what I've been telling myself
I mean, the 32bits are unaware that 64bits exist and so they don't do anything different, right?
You guys just wanna see me suffer
Is it obvious that I didn't do too well in school?
Craig
