Local Time 02:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : just spotted on EEVblog: USB to PS/2 converter - CH559 based
Posted: 03:03am 06 Sep 2022
two USB host ports for connecting a USB keyboard and mouse, and two PS/2 outputs giving keyboard and mouse data outputs:
https://www.eevblog.com/forum/projects/usb-to-ps2-converter-ch559-based/
note that rasteri uses a CH559 instead of my idea of a CH376s that does not directly output a PS/2 data stream. the CH559 seems a far tidier solution.
source code, etc. here:
https://github.com/rasteri/HIDman
apparently based on:
https://github.com/atc1441/CH559sdccUSBHost
rob   :-)
Edited 2022-09-06 13:06 by robert.rozee
Posted: 06:32am 06 Sep 2022
To use with the CMM2? Or, what?
Does it work?
Posted: 06:50am 06 Sep 2022
having followed the links, you know as much as me
it is probably fair to say it works to at least some reasonable degree, but like all such open-source projects will progress and evolve. if CMM2 production restarts in a few years time, it would be a candidate to replace the present mouse (and keyboard) solution used.
"Or, what?": for anyone who finds them in a land without PS/2 keyboards and mouses, and a need.
rob   :-)
Posted: 06:56am 06 Sep 2022
picomite could use a USB keyboard input.
The PS2 keyboards second hand are drying up in Netherlands.
And the choice in new ones is limited between toys (small) to expensive.
Posted: 08:24am 06 Sep 2022
I suspect that it probably works. You should be able to do USB to PS/2 keyboard conversion on anything that can work with a USB keyboard and has a couple of GPIO pins - any old RPi that you might find in a drawer, for example. However, you almost certainly won't get a mouse of any sort working on a PicoMite (before anyone asks).
Posted: 08:39am 06 Sep 2022
" you almost certainly won't get a mouse of any sort working on a PicoMite (before anyone asks)"
If one is sufficiently desperate to have a mouse for the LCD 'mites, write software for the external MCU to emulate a touch controller chip.
Posted: 09:09am 06 Sep 2022
I think you'd have to be desperate to do that. :)
stanleyella
Posted: 05:04pm 06 Sep 2022
I have 4 ps2 keyboards. My son asked why I did not bin them. I am a hoarder.
I do not have any ps2 mice though. If I remember they were those with a ball not laser and were always a pain to use.
Turbo46
Posted: 04:02am 07 Sep 2022
  Mick said  However, you almost certainly won't get a mouse of any sort working on a PicoMite
If you have a serial port, the Hobbytronix or Silicon Chip USB mouse to serial interface can (and has been ) used.
Also Raros used an old serial mouse with the maximite.
Edit: Silicon Chip did say that the were thinking of producing a USB Keyboard to PS/2 version of the software for that unit but nothing has happened yet as far as I know.
Edited 2022-09-07 14:06 by Turbo46
Posted: 04:23am 07 Sep 2022
  Mixtel90 said  However, you almost certainly won't get a mouse of any sort working on a PicoMite (before anyone asks).
My PS2 to WiiClassic (Arduino nano) also outputs serial so, if you really wanted to, it can be done.
Posted: 05:57am 07 Sep 2022
I don't think it matters how you interface a mouse, the PicoMite is the bottleneck as in order to move a mouse pointer smoothly on screen it has to be interrupt driven. The PicoMite VGA (I'm discounting mice on LCD displays as there's no real point if you can have a touch screen) is already pretty heavily laden in that respect. Converting mouse movement to a serial stream, even if you filter out the judder with another processor, is still going to give quite an overhead just to process the mouse movement.
Turbo46
Posted: 06:46am 07 Sep 2022
If I recall correctly, the cursor movement when using the Silicon Chip device was quite smooth on the 80MHz CMM1. It was interrupt driven and I left the serial baud rate at the default 9600.
The VGA Picomite should be more capable I would expect. I'll give it a go when time permits.
