Local Time 08:51 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Paging Volhout
Tinine
Posted: 08:57am 03 Sep 2022
I remember that you are a PLC guy.
Client is dead in the water, needs a PLC battery QTC85, aka 3B6880.
Can't wait for US delivery.
Do you have a source, please?
Craig
Posted: 09:32am 03 Sep 2022
Sorry Craig,
No clue from this side.
Bleep
Posted: 10:24am 03 Sep 2022
As a temporary, get you going measure, any lithium battery with solder tags will be fine, I doubt if the voltage is that critical, as long as its somewhere in the region of 3.6v.
lew247
Posted: 10:59am 03 Sep 2022
Try here
Sorry ignore missed the NOT usa
Edited 2022-09-03 21:04 by lew247
Posted: 12:14pm 03 Sep 2022
Here: https://www.smallbattery.company.org.uk/sbc_3B880.htm
Any 3.6V lithium will work, Craig. It may not fit the holes though.
Edited 2022-09-03 22:16 by Mixtel90
Tinine
Posted: 01:50pm 03 Sep 2022
Many thanks, guys. Yeah the voltage is not the problem, it's the 3 pins. Thanks Mick, I already found that place but no stock. I thought I found one at Radwell until I read the USA small print.
Craig
Posted: 02:49pm 03 Sep 2022
Do the pins on the blue layered sort line up, I wonder?
Edit:
No, they don't. And they are rechargeable anyway. :(
The pins are easy. The middle one is + and both the others are -
If you have space you could pop a wired AAA lithium in there. The problem is in finding a primary cell.
Edited 2022-09-04 00:58 by Mixtel90
Rickard5
Posted: 04:43pm 03 Sep 2022
I Could have brought you one on Concord, Except Apparently Lucas Prince of insufficient light was somehow involved, so _____ ME No concord Ride for me :(
circuit
Posted: 07:26pm 03 Sep 2022
RS Components;
https://uk.rs-online.com/web/p/computer-backup-batteries/0594268
This is a lithium thionyl chloride backup battery with flying leads; same chemistry as the QTC85, available next day.  Slightly higher spec and dimensions but I would expect it to do the job okay if you can find space for it.
Tinine
Posted: 08:55pm 03 Sep 2022
Been handling the situation remotely and the guys have next to no skills.
I charge 4 figures for a call-out and so he's trying to avoid that.
There is space and I know that I could cobble something together if I was there.
Of course this is the UK and this super-panic-emergency gets put on hold until Monday
Craig
