Local Time 09:11 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Testing a-d
stanleyella
Posted: 01:44am 26 Aug 2022
Just experimenting with a-d. This was after using the gauge graphics.
I have a wave generator but must protect the 3.3V max in on gpio.
https://youtu.be/0yDZQDpXL1M
easy
OPTION BASE 0        ' 0 based arrays
OPTION EXPLICIT
dim count%
dim myvoltage!
Dim samples!(237)
Dim old_samples!(237)
'colour shortcuts
const WH =RGB(255,  255,  255) 'WHITE
const YE =RGB(255,  255,    0) 'YELLOW
const LI =RGB(255,  128,  255) 'LILAC
const BR =RGB(255,  128,    0) 'BROWN
const FU =RGB(255,  64,   255) 'FUCHSIA
const RU =RGB(255,  64,     0) 'RUST
const MA =RGB(255,  0,    255) 'MAGENTA
const RE =RGB(255,  0,      0) 'RED
const CY =RGB(0,    255,  255) 'CYAN
const GR =RGB(0,    255,    0) 'GREEN
const CE =RGB(0,    128,  255) 'CERULEAN
const MI =RGB(0,    128,    0) 'MIDGREEN
const CO =RGB(0,    64,   255) 'COBALT
const MY =RGB(0,    64,     0) 'MYRTLE
const BL =RGB(0,    0,    255) 'BLUE
const Bk =RGB(0,    0,      0) 'BLACK
const Gy =RGB(128,  128,  128) 'GREY
const Lg =RGB(210,  210,  210) 'LITEGREY
const Og =RGB(255,  165,    0) 'ORANGE
const PK =RGB(255,  160,  171) 'PINK
const Gd =RGB(255,  215,    0) 'GOLD
const SA =RGB(250,  128,  114) 'SALMON
const BE =RGB(245,  245,  220) 'BEIGE
SETPIN GP26, AIN
cls
for count%=0 to 237
 samples!(count%)=(PIN(GP26)*50)+140 'get new samples
 old_samples!(count%)=samples!(count%) 'copy samples to old_samples
 line count%,samples!(count%),count%+1,samples!(count%)+1,1,wh 'draw first samples
next count%
do
for count%=0 to 237
 line count%,old_samples!(count%),count%+1,old_samples!(count%)+1,1,bk 'erase last samples
 line count%,samples!(count%),count%+1,samples!(count%)+1,1,wh 'draw new samples
 old_samples!(count%)=samples!(count%) 'copy new samples to last samples
next count%
loop
Thanks for the colours.
Posted: 07:11am 26 Aug 2022
Would love to look at your video, but YouTube won't let me.
Says it is private, which it probably is.
If you could make it public and reshare the link, I'd like to see your wee video.
stanleyella
Posted: 03:06pm 26 Aug 2022
  Grogster said  Would love to look at your video, but YouTube won't let me.
oops, It was not published. Try https://youtu.be/cVlZn1JXYHk
It just shows noise or mains hum.
The pico runs from 3.3V but watch the display when the usb programming lead is removed.
It was late at night when I coded it. My first attempt I just drew the samples and used CLS. It's just a bit of fun, not a scope yet.
