Local Time 09:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pin 0 is reserved on startup
martrogers
Posted: 12:50am 22 Aug 2022
Hello
I have successfully used MMedit on this Picomite previously but am now getting this error:
When I change SETPIN GP17, DOUT  to SETPIN 22, DOUT the line works but an error is
generated by the BITBANG line -  Unknown command
I have tried  OPTION CPUSPEED 100000 but it errors  Invalid option
I have tried differed Picos
I have tried PC and laptop
All give the same errors
Versions 5.0503 and 5.07.05b17 produce the same errors ( but I notice that during upload version 5.0503 is reported for the 5.07.05b17 version.)
These issues came after I added SD card commands to a longer code than the one shown,  not sure if that is a coincidence.
Can anyone help?
Martin
P.S Many thanks to all involed for a fabulous microcontroller system.
Posted: 01:01am 22 Aug 2022
What does OPTION LIST report?
What firmware version?
What actual hardware?
Output of: ?mm.ver,mm.device$
What are you connected to? I haven't used MMEdit in a while, so I'm not sure of the meaning of: tassyjim.ddns.net:3002
The error may indicate that GP17 is undefined, and therefor has a value of 0, which might indicate that you aren't connected to what you think you are.
Try putting OPTION EXPLICIT as the first line in your program.
The question might be, Are you in fact connected to tassyjim's test mmbasic device, and not your picomite?
Edited 2022-08-22 11:20 by lizby
Posted: 01:18am 22 Aug 2022
"... reserved on startup"
That does hint that there may be a conflict with one of your OPTIONs.
However "Pin 0" doesn't help much as there is no Pin 0. GP0 is Pin 1 so perhaps Pin 0 means an unidentified pin.
Posted: 02:27am 22 Aug 2022
  Quote   tassyjim.ddns.net:3002
indicates that he is trying to run picomite code on my micromite.
Solution: connect locally to your device.
martrogers
Posted: 02:43am 22 Aug 2022
Thanks Jim, perfect
I had assumed that it had picked up my COM3 connection after I had placed it in the connection list. I have done many projects with this editor with no issues.
Onward!
Martin
