Local Time 03:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CLS and puTTY and TeraTerm
VK2AHB
Posted: 02:16am 12 Aug 2022
I'm a newbie to the pico/MMBasic world, but started with BASIC in the 80's with a Sharp PC1211, then C=64. It sure has changed in 40 years!  I'm amazed at the functionality crammed into such a small, cheap device!
I've started with simple stuff, like reading RTC and temperature from bits I've been using with the Auduino Nano.  Sure is interesting to compare the amount of code and libraries required for C++ against MMBasic!  So I print Date, Time and temperature with a delay of 10 seconds, then issue the CLS command.
My immediate problem is CLS in terminal mode. With the VGA monitor, it does as its asked, but in terminal, it keeps printing new lines. I'd appreciate help in what might be a trivial setting.
Paul VK2AHB
Posted: 02:38am 12 Aug 2022
Hi and welcome.
To erase the terminal, you need to send it the escape codes
ESC[2J Erase the screen
Somewhere in the recent past, there was a post with subs for many of the esc sequences that are commonly used.
Posted: 02:45am 12 Aug 2022
  TassyJim said  Somewhere in the recent past, there was a post with subs for many of the esc sequences that are commonly used.
Mixtel90's VT100 library for the Micromite console
Posted: 02:48am 12 Aug 2022
Thanks,
I was almost back to there. I had a couple of pages to go!
Posted: 07:30am 12 Aug 2022
Hi Paul, and welcome to the forum. :)
I was confused by this originally, don't worry. :) The PicoMite has two output devices, one is a console (which supports ANSI escape codes) and the other is a graphic device. When you first boot up you are in console mode by default. Note that the two devices don't have to be two physical devices, they can be different displays on the same screen. Error and information messages are sent to the console. User output can be to either.
Each device has its own commands to output text:
The console uses PRINT, which puts ASCII characters in cells as expected.
The graphic display uses TEXT, which draws text on a graphic screen at any location.
CLS is actually a graphic command and means nothing to an ANSI console. This is where the ANSI sequence ESC[2J comes from.
There are a lot of these sequences that work on the console. The link that Lizby has given is a library of quite a few useful ones that work on Tera Term.
Martin H.
Posted: 09:06am 12 Aug 2022
Const el$=Chr$(27)+"["
'Your Program
SUB tcls
' clear terminal screen
PRINT el$;"2j";
home
END SUB
SUB home
' cursor top left
PRINT el$;"h";
END SUB
SUB at row,col
PRINT el$;;STR$(row);"h";el$;STR$(col);"g";
END SUB
Sub cur_off
  Print el$"?25l";
End Sub
Sub cur_on
  Print el$;"?25h";
End Sub
tcls= Terminal CLS
home = Cursor to top left
at positions the Cursor to row/column
Cur_off / Cur_on hides the Cursor while redrawing the Screen
Edited 2022-08-12 19:11 by Martin H.
'no comment
VK2AHB
Posted: 01:12am 13 Aug 2022
Thanks to all who replied, that was very helpful.
Paul VK2AHB
