Local Time 09:40 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3 Picomite bug reports and also request an enhancement
KenH
Posted: 01:33pm 08 Aug 2022
Hello
I would like to report 3 Picomite bug reports and also request an enhancement.
In summary, the bug reports are:
time$ cannot be set as the result of a function (date$ seems OK)
"GUI formatbox activate" and "GUI numberbox activate" fail, but "GUI textbox activate" seems OK
If you return to the command prompt <Ctl> C from other than page 1 you get "Error: Invalid address - resetting" and the program is deleted
Enhancement request - a method to increase the font size for formatbox and numberbox as currently is it very very small and much smaller than shown in the manual.
My wife is slightly visually impaired and has no chance of seeing the very small numbers.
I am using LCDpanel ILI9488.
Below example programs to illustrate each error.
Ken
Function I2time(hh, mm) As string
I2time = STR$(hh,2,0,"0") + ":" + STR$(mm,2,0,"0")
end function
Dim buff as string
buff = I2time(12,20)
time$ = buff
print time$, "  ", buff
time$ = I2time(12,20)
Saved 176 bytes
> Run
12:20:00  12:20
[8] Time$ = I2time(12,20)
Error : Expected a number
"GUI formatbox activate" and "GUI numberbox activate" fail.
Note different errors depending upon whether option explicit or not.
option explicit
cls
GUI formatbox #1,time1,0,0,160,50,rgb(white),rgb(black)
GUI formatbox activate #1
Saved 99 bytes
> Run
[4] GUI formatbox activate #1
Error : ACTIVATE is not declared
cls
Saved 86 bytes
> Run
[3] GUI formatbox activate #1
Error : Expression syntax
(Sorry that this example is quite long, but shorter ones don't seem to fail!)
Autosave
Dim switch = 1
Dim old_switch = 0
Sub S1
Print "Sub S1"
GUI interrupt 0
GUI delete all
GUI setup 1
Font #5,1
GUI caption #1,"Line 1", 0,0,"LT",RGB(white)
GUI caption #2,"Line 2", 0,50,"LT",RGB(white)
GUI caption #3,"Line 3", 0,100,"LT",RGB(white)
GUI caption #4,"Line 4", 0,150,"LT",RGB(white)
GUI caption #5,"Line 5", 0,200,"LT",RGB(white)
GUI button #6,"Button",0,250,200,40,RGB(black),RGB(cyan)
GUI interrupt S1down
Page 1
end sub
Sub s1down
Print "Sub S1down"
if touch(ref) = 6 then
 switch = 2
end if
end sub
Sub S2
Print "Sub S2 - Now I will press <Ctl> C"
GUI interrupt 0
GUI delete all
GUI setup 2
Font #5,1
GUI button #1,"Button",0,100,200,40,RGB(black),RGB(cyan)
GUI interrupt S2down
Page 2
end sub
Sub s2down
Print "Sub S2down"
if touch(ref) = 1 then
 switch = 1
end if
end sub
cls
do
if switch <> old_switch then
 old_switch = switch
 select case switch
  case 1
   S1
  case 2
   S2
 end select
end if
loop
Saved 915 bytes
> Run
Sub S1
Sub S1down
> Autosave
Posted: 03:05pm 08 Aug 2022
1 is trivial will fix in next beta. Workround as you found or
Function I2time$(hh, mm)
I2time$ = STR$(hh,2,0,"0") + ":" + STR$(mm,2,0,"0")
end function
Dim buff as string
buff = I2time$(12,20)
time$ = buff
time$ = I2time$(12,20)
2 appears to be a manual issue. There is no PicoMite code to support this functionality and nothing in Geoff's latest source which is where the Picomite code comes from. Will inform Geoff
3 Unable to test as not at home. If you can change example to use a 320x240 display I could possibly test
Re enhancement, the code autosizes the font based on the resolution of the display. I don't know if there is a bigger font that would fit the cell size on a 480x320 display but will have a look when back home (3 weeks)
KenH
Posted: 07:39pm 08 Aug 2022
Hello Peter
Many thanks for the prompt reply.
Re 1 as you say, not a major problem - just worked with Micromite. Easy enough to get around.
Re 3, I have run this again with  LCDPANEL ILI9341 320 x 240 and get the same error - "Error: Invalid address - resetting". Unfortunately, the error seems very dependent upon the layout of page 1. Some layouts work, some don't but the error is consistent and not random. 320 x 240 program below. If you delete one or more of the GUI caption lines, the error goes away!
Re the enhancement request, I have run this again with  LCDPANEL ILI9341 320 x 240 and the font appears bigger and fills more of the buttons. With LCDPANEL ILI9488 480 x 320 the font appears smaller and fills much less of the button. The font could be quite a lot bigger without spilling over boundaries.
Thanks again
Best wishes
Ken
option list
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION SYSTEM I2C GP20,GP21
OPTION LCDPANEL ILI9341, RLANDSCAPE,GP8,GP15,GP9
OPTION GUI CONTROLS 50
OPTION TOUCH GP16,GP17
GUI CALIBRATE 0, 341, 199, 886, 629
> Autosave
Dim switch = 1
Dim old_switch = 0
Sub S1
Print "Sub S1"
GUI interrupt 0
GUI delete all
GUI setup 1
Font #5,1
GUI caption #2,"Line 2", 0,40,"LT",RGB(white)
GUI caption #3,"Line 3", 0,80,"LT",RGB(white)
GUI caption #4,"Line 4", 0,120,"LT",RGB(white)
GUI caption #5,"Line 5", 0,160,"LT",RGB(white)
GUI button #6,"Button",0,200,200,40,RGB(black),RGB(cyan)
Page 1
end sub
Sub s1down
Print "Sub S1down"
 switch = 2
end if
end sub
Sub S2
GUI interrupt 0
GUI delete all
GUI setup 2
Font #5,1
Page 2
end sub
Sub s2down
Print "Sub S2down"
 switch = 1
end if
end sub
cls
do
 old_switch = switch
 select case switch
  case 1
   S1
  case 2
   S2
 end select
end if
loop
Saved 914 bytes
> Run
Sub S1
Sub S1down
> Autosave
Posted: 01:09am 09 Aug 2022
I can confirm the bug.
Trying to enter 'NEW' also causes the error but 'CPU RESTART' works and the program is safe and sound after the restart.
Posted: 09:03am 09 Aug 2022
OK Found the bug. It is caused by the use of GUI DELETE which clearly has never been used before as it frees up memory but doesn't de-allocate the pointer. Then when NEW or AUTOSAVE test the pointer and given that it is set also try and free up the memory bad things happen. Will fix in next V5.07.05 beta
KenH
Posted: 11:19am 09 Aug 2022
Many thanks for identifying the problem.
I am converting a program which was "shoe horned" into a Micromite which has 17 screens (pages). Converting it to use the the advanced graphics in the Picomite along the way. I use GUI Delete at the start of each page, otherwise I would have to set Option GUI controls to a very high number.
Many thanks again.
Ken
KenH
Posted: 02:19pm 18 Aug 2022
Hello Peter
I have discovered a few more minor bugs whilst working with advanced GUI controls:
When you change pages the 'UP' icon of a spinbox is not erased.
The rest of the spinbox is erased as expected. The program below demonstrates.
Tested with both ILI9488 and ILI9341.
If you touch a radio button very briefly (say with a stylus) the radio button changes, but a GUI Interrupt is not triggered.
Similarly, pressing an ordinary button very briefly makes it stay in the 'pressed' position with no interrupt.
Sometimes the 'UP' or 'DOWN' icons on a spinbox stay illuminated and the control freezes. This may well be the same issue as with buttons.
Best wishes
Ken
cls
GUI setup 1
Font #3,1: GUI spinbox #1,50,50,150,35,RGB(cyan),RGB(32,32,32),1,0,10
Font #3,1: GUI spinbox #2,100,150,200,50,RGB(cyan),RGB(32,32,32),1,0,10
Page 1
pause 5000
GUI setup 2
Page 2
