Local Time 09:48 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mmb4l on ChromeBook?
gadgetjack
Posted: 02:11am 06 Aug 2022
I am asking thwill if this is even possible. I got a chromebook for Christmas and I carry it  a lot. Would be nice to play some mmbasic code while I travel.
Posted: 03:33am 06 Aug 2022
Hi gadgetjack,
In case mmb4l has problems on your chromebook, when it is a x86 type chromebook (not arm) you could try Wine and mmb4w. To get Wine to run, here is a guide how to do it.
https://internetbankroll.com/wine-on-chromebook/
I run mmb4w under ubuntu 20.04 wine. And it works fine.
Actually, I modded my chromebook to run GalliumOS which is a ubuntu derivative, so it could be used for other than web apps. But I never tried mmb4l on the chromebook. So in that perspective I cannot help you.
Edited 2022-08-06 13:39 by Volhout
Posted: 05:42am 06 Aug 2022
Hi @gadgetjack,
It is in theory possible - though you may have to build it for yourself from source; it depends on the architecture of your Chromebook, x86_64, aarch64, ... ?
You would also need to enable Linux on your Chromebook https://chromeos.dev/en/linux. .
Please note that MMB4L does not have all the graphical goodness of MMB4W, it is still strictly a console affair.
In case anyone was wondering, MMB4L isn't dead, it's just simmering and I haven't been talking about it because nobody seems to have anything other than academic interest.
Edited 2022-08-06 18:43 by thwill
Posted: 09:07am 06 Aug 2022
  thwill said  You would also need to enable Linux on your Chromebook https://chromeos.dev/en/linux. .
sole affair.
Typo (trailing .) the URL is this
I've been following MMB4L but figured you're busy and I'm in no hurry.
Posted: 02:57pm 06 Aug 2022
  JohnS said  I've been following MMB4L but figured you're busy and I'm in no hurry.
Thanks John, and yes, there is a good deal of truth in that.
Posted: 03:46pm 06 Aug 2022
I've used MMB4L with armcfgenV143.bas
gadgetjack
Posted: 05:36pm 06 Aug 2022
Big thanks to Volhout !!! I tried wine and mmbb4w runs ok. Still trying to figure out how to edit , my book has no function keys...but I can get around that I think with a text editor. You got me started so , again , big thanks from Gadgetjack.
Posted: 07:42pm 06 Aug 2022
  Quote  Still trying to figure out how to edit , my book has no function keys
see EDIT chapter in CMM2 manual for ctrl codes that can be used instead of function keys
Edited 2022-08-07 05:43 by matherp
Posted: 02:41am 07 Aug 2022
Hi gadgetjack,
Try holding the search key wit one of the keys in the top row.
Edited 2022-08-07 14:32 by Volhout
gadgetjack
Posted: 04:42pm 07 Aug 2022
Ok , the search key was the trick. Thanks Volhout.  And thanks to Matherp or I would not be playing with this in the first place. I love this site.
