Local Time 03:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A simple Sudoku solver
Posted: 05:41pm 05 Aug 2022
This code is designed for the VGA Picomite but should run with minor changes on other platforms
It will solve puzzles that do not need guesses. It could be built on to guess and then see if a guess yields a solution - feel free to add and post
It contains a test puzzle which is displayed on startup. To run the solver with the test puzzle press the escape key to start the process.
You will see the matrix of possible valid values in the right of the screen as the solver works.
The solution is filled in on the left of the screen.
There is a lot of cut/paste/modify in the code so if you see an error please report.
To enter a new puzzle press any other character and then you can step through the puzzle entering the values. Use space for an unknown value. Once the last cell is entered the solver will start.
Enjoy
sudoku.zip
Option base 1
Option explicit
Option default integer
CLS
Dim rowb,colb,row,col
dim s$
Dim a%(3,3,3,3,9) 'rowb, colb, row, col, not eliminated
' a possible value is if not seen in rowb=row, colb=col and not in any row/col
Math set 1,a%() 'set all values as possible
'load sample grid
Dim g%(3,3,3,3)
Dim w=MM.Info(fontwidth)
Dim h=MM.Info(fontheight)
Dim i,j,found,eloop, solved
'replace this with a gui
g%(1,1,1,1)=4
g%(1,1,3,1)=6
g%(1,2,2,2)=7
g%(1,2,3,3)=5
g%(1,3,1,1)=6
g%(1,3,2,2)=2
g%(1,3,3,2)=1
g%(2,1,1,2)=8
g%(2,1,2,1)=9
g%(2,1,3,1)=5
g%(2,2,2,1)=2
g%(2,2,3,3)=6
g%(2,3,1,3)=4
g%(2,3,2,3)=3
g%(2,3,3,2)=7
g%(3,1,1,2)=4
g%(3,1,2,2)=1
g%(3,1,3,3)=7
g%(3,2,1,1)=3
g%(3,2,2,2)=9
g%(3,3,1,3)=2
g%(3,3,3,3)=8
displaygrid
do
loop until inkey$=""
do
s$=inkey$
loop until s$<>""
if s$<>chr$(27) then
 For i=0 To 9
   Line w,i*h*3,w*3*9+w,i*h*3,Choice(i Mod 3=0,2,1)
   Line w*i*3+w,0,w*i*3+w,h*3*9,Choice(i Mod 3=0,2,1)
 Next
 For rowb=1 To 3
   For row=1 To 3
     For colb=1 To 3
       For col=1 To 3
         print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)"-";
         do
         i=asc(inkey$)-48
         loop until (i>=1 and i<=9) or i=-16
         if i>0 then
           print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)str$(i,1);
         else
           print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)" ";
         endif
         g%(rowb,colb,row,col)=choice(i>0,i,0)
       next col
     next colb
   Next row
 next rowb
 displaygrid
 pause 1000
endif
' first pass look for cells that are now completely defined
DO
 solved=1
 do
   displaygrid
   setup
   possible
   eloop=1
   For colb=1 To 3
     For col=1 To 3
       For rowb=1 To 3
         For row=1 To 3
           j=0
           for i=1 to 9
             If a%(rowb,colb,row,col,i) Then
               inc j
               found=i
             endif
           next i
           if j=1 then
             g%(rowb,colb,row,col)=found
             eloop=0
           endif
         Next row
       next rowb
     next col
   next colb
 loop until eloop=1
 scancol eloop
 if eloop=0 then solved=0
 scanrow eloop
 scanblock eloop
loop until solved=1
For colb=1 To 3
 For col=1 To 3
   For rowb=1 To 3
     For row=1 To 3
       if g%(rowb,colb,row,col)=0 then solved=0
     Next row
   next rowb
 next col
next colb
if solved=0 then TEXT 50,400,"FAILED",,,3
end
sub scancol(eloop)
 eloop=1
 local colb,col,rowb,row,i,j, foundr, foundrb
 For colb=1 To 3
   For col=1 To 3
     for i=1 to 9
       j=0
       for rowb=1 to 3
         for row = 1 to 3
           if a%(rowb,colb,row,col,i) then
             inc j
             foundr=row
             foundrb=rowb
           endif
         next row
       next rowb
       if j=1 then
         g%(foundrb,colb,foundr,col)=i
         eloop=0
       endif
     next i
   next col
 next colb
end sub
sub scanrow(eloop)
 eloop=1
 local colb,col,rowb,row,i,j, foundc, foundcb
 For rowb=1 To 3
   For row=1 To 3
     for i=1 to 9
       j=0
       for colb=1 to 3
         for col = 1 to 3
             inc j
             foundc=col
             foundcb=colb
           endif
         next col
       next colb
       if j=1 then
         g%(rowb,foundcb,row,foundc)=i
         eloop=0
       endif
     next i
   next row
 next rowb
end sub
sub scanblock(eloop)
 eloop=1
 local colb,col,rowb,row,i,j, foundc, foundr
 For rowb=1 To 3
   For colb=1 To 3
     for i=1 to 9
       j=0
       for row=1 to 3
         for col = 1 to 3
             inc j
             foundc=col
             foundr=row
           endif
         next col
       next row
       if j=1 then
         g%(rowb,colb,foundr,foundc)=i
         eloop=0
       endif
     next i
   next colb
 next rowb
end sub
sub displaygrid
 cls
 For i=0 To 9
 Next
 Print ""
 For rowb=1 To 3
   For row=1 To 3
     For colb=1 To 3
       For col=1 To 3
         If g%(rowb,colb,row,col) Then
           Print Str$(g%(rowb,colb,row,col),3);
         Else
           Print "   ";
         EndIf
       Next col
     Next colb
     Print ""
     Print ""
     Print ""
   Next row
 Next rowb
 For i=0 To 9
 Next
end sub
sub checkcols
 For colb=1 To 3
   For col=1 To 3
     For rowb=1 To 3
       For row=1 To 3
         if g%(rowb,colb,row,col) then
           for i=1 to 3
             for j=1 to 3
               if NOT (i=rowb and j=row) then modcell(i,colb,j,col,g%(rowb,colb,row,col))
             next j
           next i
         endif
       Next row
     next rowb
   next col
 next colb
end sub
sub checkrows
 For rowb=1 To 3
   For row=1 To 3
     For colb=1 To 3
       For col=1 To 3
           for i=1 to 3
             for j=1 to 3
               if NOT (i=colb and j=col) then modcell(rowb,i,row,j,g%(rowb,colb,row,col))
             next j
           next i
         endif
       Next col
     next colb
   next row
 next rowb
end sub
sub setup
 For rowb=1 To 3
   For row=1 To 3
     For colb=1 To 3
       For col=1 To 3
           for i=1 to 3
             for j=1 to 3
               modcell(rowb,colb,i,j,g%(rowb,colb,row,col))
             next j
           next i
           for i=1 to 9
             If g%(rowb,colb,row,col) <>i Then
               modcell(rowb,colb,row,col,i)
             endif
           next i
         endif
       Next col
     Next colb
   Next row
 next rowb
 checkcols
 checkrows
end sub
sub modcell rowb,colb,row,col, veto
 a%(rowb,colb,row,col,veto) =0
end sub
sub possible
 local colb,col,rowb,row,i,j,found
 for rowb=1 To 3
   For row=1 To 3
     For colb=1 To 3
       For col=1 To 3
         for i=1 to 9
             print @(MM.HRES\2+((colb-1)*12+(col-1)*4+(i-1) mod 3)*w,((rowb-1)*12+(row-1)*4+(i-1)\3)*h+h\2)str$(i,1);
             found=1
           else
             print @(MM.HRES\2+((colb-1)*12+(col-1)*4+(i-1) mod 3)*w,((rowb-1)*12+(row-1)*4+(i-1)\3)*h+h\2)" ";
           endif
         next i
       Next col
     Next colb
   Next row
 Next rowb
 if found then
   For i=0 To 9
     Line MM.HRES\2+w*i*4-w\2,0,MM.HRES\2+w*i*4-w\2,h*3*12,Choice(i Mod 3=0,2,1)
     Line MM.HRES\2-w\2,i*h*4,MM.HRES\2-w\2+w*36,i*h*4,Choice(i Mod 3=0,2,1)
   Next i
 endif
end sub
Edited 2022-08-06 03:42 by matherp
hitsware2
Posted: 01:59am 08 Aug 2022
I had a dream that You put Your efforts
into improving Your PLAY SOUND routine .
my site
Posted: 04:21am 08 Aug 2022
I thought about writing one myself, but never came to do it.
It is one of those puzzles I like playing, although the 5* ones take some time.
How did you come up with the idea to use a 3x3x3x3x9 matrix (the 3x3x3x3 I understand, but actualy 9 layers, one for each possible digit in each cell).
You hear already, I havent given it sufficient time to think my own solver solution...
Posted: 08:18am 11 Aug 2022
Hi Peter,
Nice piece of work. I finally got to running it and it is nice to see the solver at work on the right hand side of the screen. Just great..!!
