Local Time 10:07 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Array manipulation PicoMIte
Bleep
Posted: 09:09pm 24 Jul 2022
Hi, does anyone know if it's possible to add or multiply one single dimension array by a second single dimension array with a single command, similar to the MATH function.
So for example add each of the array elements 0 1 2 3 4...etc to elements 0 1 2 3 4...etc of another array & put the results in to elements 0 1 2 3 4...etc of a third array (or one of the input arrays), similar for multiply. As far as I can see the MATH_M_MULT only works on 2D arrays for example,
This is purely for speed, I realise I can do a For loop, but the MATH functions are much more optimised.
Thanks Kevin.
Posted: 12:14am 25 Jul 2022
Hi Bleeb,
The math functions are in picomite, even MATH FFT
See manual
Edited 2022-07-25 10:16 by Volhout
Martin H.
Posted: 06:36am 25 Jul 2022
by calling a Sub or a Function you can move a complete array into another array
Dim aa(20,20)
For f=1 To 20
For n=1 To 20
aa(f,n)=Int(Rnd*255)
Next n
Next f
show aa()
Sub show bb()
For f=1 To 20
For n=1 To 20
Print bb(f,n);",";
Next n
Print
Next f
End Sub
'no comment
Bleep
Posted: 07:52am 25 Jul 2022
HI, Yes, as I said I've been all through the MATH functions, they don't seem to work on 1D arrays, that was why I am asking if anyone knows of anything else; Similarly, as I stated I know I can do this using For loops, but built in functions are always going to be much quicker.
I am adding and multiplying several 192 element 1D arrays, which are then being used to draw on the screen using the Polygon command, so they need to be 1D and they need to be fast.
Regards, Kevin.
Edited 2022-07-25 20:15 by Bleep
