Local Time 10:07 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite VGA Mode 1 Sprite Transparency ???
Sasquatch
Posted: 02:26am 24 Jul 2022
PicoMite VGA  V5.07.05b15
Sprite transparency does not seem to be working in Mode 1
For example, This test program works in Mode 2 but the sprite is not transparent in Mode 1
 CLS
 XMax = MM.HRes - 1
 YMax = MM.VRes - 1
 'Make a Sprite
 Line 10,0,10,20
 Line 0,10,20,10
 Circle 10,10,7
 Sprite Read #1,0,0,20,20
 CLS
 'Put some art on the screen
 For X = 1 To 100
   Line Rnd(0) * XMax,Rnd(0) * YMax,Rnd(0) * XMax,Rnd(0) * YMax
 Next X
 'Now move the sprite across the screen
 For X = 10 To 300
   Sprite Show #1,X,MM.VRes/2,1
   Pause 10
 Next X
-Carl
Posted: 05:50am 24 Jul 2022
I don't think it can. Mode 1 is a 2-colour mode, there is only foreground and background. It is superimposed over the TILE matrix to add some colour, you can't actually draw several different things in different colours.
Posted: 07:37am 24 Jul 2022
  Quote  Sprite transparency does not seem to be working in Mode 1
I sort of assumed no-one would use it so it hasn't been implemented. I'll look at it next time I open that code
Sasquatch
Posted: 07:24pm 24 Jul 2022
  Mixtel90 said  I don't think it can. Mode 1 is a 2-colour mode, there is only foreground and background. It is superimposed over the TILE matrix to add some colour, you can't actually draw several different things in different colours.
Black or RGB(0,0,0) is the transparent "color" on the PicoMite VGA.  I was trying to overlay a cursor sprite on Mode 1 graphics.  The Sprite works perfectly but it has black square around it.  I hadn't considered the color tiles, but I suppose they would also affect the Sprite color in Mode 1.
-Carl
Posted: 07:41pm 24 Jul 2022
Tiles may make things interesting as they change both the foreground and background colours on a cell by cell basis. As you can (currently anyway) only have one of each at any one moment it might be like waving a rainbow around (where's Jeff MInter when you need him?). Very cool, but distinctly odd. :)
