Local Time 03:40 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicomiteVGA and SPI bus
Gurgs
Posted: 02:29pm 16 Jul 2022
I have a question about the SPI bus and the PicomiteVGA.
I have an SDCard set up with the following option...
   OPTION SDCARd GP10, GP11, GP12, GP13
and it is working correctly.
If I wish to add another SPI device to my PicomiteVGA do I need to use the second
SPI bus or can I use the same bus as the SDCard but with a different cable select
pin under software control.
I assume this would depend on whether the SDCard CS pin is kept high at all times
or only when MMBASIC accesses the SDCard.
Thanks in advance.
Posted: 02:40pm 16 Jul 2022
You should be able to add additional SPI devices on the same MISO/MOSI/CLK pins with a separate chip select pin.
Posted: 03:17pm 16 Jul 2022
The SDcard doesn't use the SPI bus on the VGA version, it is bitbanged, the pins can't be shared. You can though use both SPI1 and SPI2 on other pins
Gurgs
Posted: 06:28pm 16 Jul 2022
Thank you very much, this is very helpful.
