Local Time 03:41 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Format text for display on LCD
Glen0
Posted: 09:17pm 13 Jul 2022
I have been trying to display the temperature from an MCP9700 to an SPI LCD as seen in the attached photo.
The code below shows what steps and variations I have been trying.
'Temperature from MCP9700 and ADC test
SetPin 34, Ain
 A = Pin(34)-0.535
 A1 = A*100
 A2 = val (Str$ (A1, 2 ,1))
 'A3 = VAL (A2)
 'print A3
 'Print str$ (A1, 2, 1)
 'Z = Val(STR$(A,2,2))*100
 TEXT 100, 70, str$(A2), CM, 6, 1, RGB(CYAN), DBlue
 Pause 600
Loop
All is well until the displayed temp reaches exactly 20, for example, it then leaves "artifacts", (for lack of a better term,) of the previous temperature.
I can get it to work fine if I don't display any decimal but as soon as I try to display 1 decimal point I have this problem.
What am i doing wrong in my code.
Can someone please give me a snippet of code showing how to take an ADC reading and display it to 1 decimal point.
I am trying to avoid using CLS as much as possible, because the flashing is annoying.
MCP9700 test.zip
Posted: 09:24pm 13 Jul 2022
Try
A2$ = Str$ (A1, 2 ,1)
TEXT 100, 70, a2$, CM, 6, 1, RGB(CYAN), DBlue
Glen0
Posted: 09:33pm 13 Jul 2022
Thanks Jim, perfect.
It's all about where you put your mighty $   :-))
I need to get used to strings, values, integers etc.
Turnaround on this forum is marvellous.
Edited 2022-07-14 07:34 by Glen0
