Local Time 03:40 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3,3 V for the pico Ps2 keyboard
Plasmamac
Posted: 06:14pm 12 Jul 2022
I testet my keyboard with 3,3 V.
Its working with 3,3v.
Have you a keyboard which works with 3,3v ?
Anyone can confirm  and shows the brand here ?
Unfortunately my keyboard has no label in the back.
Gtx
Plasma
LandBoardsLLC
Posted: 06:48pm 12 Jul 2022
I've tried 3.3V operation with 5 or 6 keyboards. Most worked. I had 2 identical Microsoft Natural keyboards where one worked and the other didn't.
- Doug at Land Boards LLC
Posted: 06:50pm 12 Jul 2022
  Quote  I had 2 identical Microsoft Natural keyboards where one worked and the other didn't.
I think this is the issue. Any recommendation could not guarantee all keyboards of that make/model would behave the same.
Posted: 04:18am 13 Jul 2022
The only keyboard that I have that requires 5V power (a very old Hewlett Packard) works perfectly with the pullups going to 3.3V, so it does not need level shifters. Its a matter of testing before deciding if you can omit the level shifters.
Posted: 06:39am 13 Jul 2022
The only reason I'd leave out the level shifter on my boards now would be for miniaturisation. As a *minimum* I'd fit 270R series resistors and Schottky diodes and parallel 10k pull-ups to 3V3 because someone, somewhere will plug in a non-standard keyboard that has its own internal pullups to 5V (as do many mice). This arrangement isn't perfect, but it will give a degree of protection.
