Forum Index : Microcontroller and PC projects : Why there will not be MMBasic for the pico_w (at least from me)
| Page 1 of 3 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12185 |
Thought I should close down any further discussion re MMBasic Adds c300K to the firmware just for the wifi handler without any MMbasic code. Any bluetooth at a later date would be even more. Uses > 20K of RAM reducing program and variable space. Unclear whether this is heap or statically allocated - details sketchy Uses one PIO - details sketchy Uses interrupts - details sketchy Current example programs do not use USB - why? - incompatible? Incompatible with other boards and/or programs that use GP23,24,25,29 CPU overhead, impact on CPU1 (VGA) - details sketchy Almost certainly needs a separate binary (x2 for VGA) - maintenance overhead No MMbasic command or function slots free Accessing an ESP8266 using AT commands is much simpler Edited 2022-07-04 23:15 by matherp |
| pwillard Guru Joined: 07/06/2022 Location: United StatesPosts: 347 |
I sort of figured this would be the conclusion... It's not surprising and I agree that even they should have used ESP versus what they did. (but then I assume they also wanted Bluetooth... whatever.) The maker industry adopted ESP... but why should Raspberry Pi? ;-P |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10109 |
And there you have it.... ![]() I also expected as much. But Peter has surprised us before in the past, so till I heard it from him, I was not totally ruling it out, but still thought it highly unlikely. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9329 |
You really don't gain anything by having dedicated commands that are translated by the interpreter to send AT commands. You can still only send them at the same baud rate so there's no speed penalty. A serial device is still only going to talk to the world very slowly in digital terms so your program still sits in loops waiting for things to happen. Sending the AT commands is easy if you write a SUB with a corresponding FUNCTION to get a value back. After that, additional SUBs will make the thingy do exactly what you want - no matter whose version of the AT command set it uses. A tweak to the AT command strings and your program will work with a different device - with no major re-writing. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Completely agree. ![]() EDIT: It would be like me saying I want specific MMBASIC commands for talking to SimCom modules that I use for sending text messages on our cellphone network. It is all done in AT commands, so I just have some SUB's to deal with common things, using the SimCom AT command set manual. Edited 2022-07-05 16:56 by Grogster Smoke makes things work. When the smoke gets out, it stops! |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3888 |
If you looked at Annex Basic, you would see how much you could gain. Among a good many other things, the functionality of being able to email myself readings from a remote sensor via wifi is paramount for me--I have a dozen or so sensors in places where wiring would be awkward at the least. But I understand Peter's points and accept that it's not going to happen on the PicoMite. ~ Edited 2022-07-05 22:35 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
Don't know if I'm off on a tangent here because I haven't done anything with my ESPs yet but I do know that you can program them in BASIC, using B4R (OK, you also have to use the Arduino environment). Whether this is of any use with the PicoMite, I dunno. I do know that it's compiled and not a dog like Annex . Craig |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
Rather than a separate esp32, there are these: WIZnet Uses the 'AT' command set over serial, has 16MB flash and more. Relatively cheap, anyone played with these? led Miss you George |
You can do that using any WiFi device such as the ESP32 or ESP8266. John |
Any RF module that needs dedicated pins for linking to a PicoMite means that the combination isn't a PicoMite. As soon as you use pins that are normally available you've potentially broken existing software. I suspect that some are going to realize this when they start to use the Pico W. If you want Wi-fi nodes, web servers etc. then there are far better ways to do it than trying to hang an RF module onto a RP2040 - it doesn't have the RAM you need really and isn't usually supplied with all that much flash either. Get an ESP and use a native BASIC or whatever on that and you'll get better results. Once again, Annex is almost certainly a dog inside. It has lots of commands, yes, but I bet they are simply front-ends for AT strings that you could just as easily send over a normal COM port from a 28-pin Micromite if you so wished - and at the same speed. If not, it has to be working at register level and is consequently unusable with anything but a single chip (or a small number of them from the same manufacturer). Mick Zilog Inside! nascom.info for Nascom & Gemini |
True enough, but why use the Picomite and an ESP when the ESP will do it on its own? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Then use the ESP. I got the impression you wanted to use a Pico. If you do then for WiFi etc you'll need to add a WiFi chip (or don't use MMBasic). John |
Really, I don't see any reason to sl*g it like that. Yes, it's slower than the Picomite, but for many purposes you don't need that speed. Part of the appeal of Basic is that if it's fast enough, you don't need to care how it's implemented behind the scenes. If it isn't fast enough, there are lots of choices. This makes no sense to me at all. I think it's probably objectively wrong (after all, there are ESP SDKs), and even if it were true, you can't "easily" with a micromite send an email using an attached wifi device whether ESP or other. (For some reason, the forum is changing s l a g to sl*g--I've tried correcting it twice. Strange.) ~ Edited 2022-07-06 01:01 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I would love to use a wifi-enabled micromite. But there isn't one, so I actually do use Annex Basic on ESP in anger, even though I prefer playing with MMBasic. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I would love to use a wifi-enabled micromite. But there isn't one It would be any 'mite with a WiFi chip (on SPI, I2C, COM or whatever). It's almost as if you don't realise that email is just one use of TCP/IP and can be done on any WiFi (or other) device which does TCP/IP. John |
They are two different things though. The 'Mites are designed to be either 1980's home computer look-alikes or simple embedded control platforms. Neither of these would use Wi-fi or Bluetooth, but you could potentially use them by treating them as a modem. There are other devices that are designed to do those jobs more efficiently. It's horses for courses - you use the right tool for the job, even if they do use different languages. After all, you might, for example, need something that's extremely fast where only a compiler would do. You couldn't use MMBasic for that. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hmmm, wishlist: WiFi (for email, remote access, internet) Bluetooth Touchscreen Powerful, high-res graphics Gigabytes of memory Gigahertz processor Battery backup On-board, open-source, BASIC interpreter Low-cost Now let me think....Got it! ![]() Android tablet running RFO-BASIC and with TeamViewer or Airdroid loaded and set-up in "Kiosk" mode to restrict access. The perfect front-end for a MCU Craig Edit: Forgot to mention audio ![]() Edited 2022-07-06 01:53 by Tinine |
The fact that I cite one use that is important to me doesn't imply that I don't know of other uses, or that Annex doesn't support them, or that I haven't used them. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Exactly what Annex on an ESP8266 or ESP32 can be--except with an ability to interact wirelessly with other devices. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
And perfect for controlling an ESP device running Annex. That's how I've used it (except plain android and a browser). We're on the same page, I think. ~ Edited 2022-07-06 02:01 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| Page 1 of 3 |
